10-19-2018
10:41
15:03
10-19-2018
10:41
15:03
A text will come thru on the Charge 3 as it is supposed to, but then I cannot clear the screen of the message. I can move the message up and down, but the clear command is unresponsive. The only way I can get the message off the screen (tried hitting the home button) is to restart the device completely.
This has happened to me multiple times.
10-19-2018 14:41
10-19-2018 14:41
Welcome on board @eham, it's nice to see you around! First make sure that your tracker is already running the latest firmware version update.
Then, please try restarting your Charge 3 once again by following the steps below:
If the issue persists, I'd recommend clearing user data on your tracker.
Keep in mind that a factory reset erases all apps and personal data from Charge 3. So, please make sure to sync before doing this procedure.
On Charge 3, open the Settings app > About > Clear User Data.
Give this a go and let me know the outcome!
Best Answer02-11-2019 09:45
02-11-2019 09:45
I'm having the same problem right now. How did you restart yours?
Best Answer02-11-2019 09:50
02-11-2019 09:50
@Deni_c3, please check out @MarreFitbit post - she provided instructions right above....
Best Answer05-26-2020 05:23
05-26-2020 05:23
I changed my clock face & all is good. Basically forced it to reboot this way.
