Charge 3 won't connect to Bluetooth or synch.
Hi, my charge 3 will not connect to BlueTooth and thus, will not synch. any advice?
1 REPLY 1
@Dori93 Thanks for being part of our Community!
Let me help you with this. The bluetooth connection is handled by the Fitbit app so I suggest you try the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
