10-15-2018
02:47
15:06
10-15-2018
02:47
15:06
The charge 3 stopped connecting to my iPhone so now the app is worthless and I can’t track sleep or anything on the app. This happened 2 days after getting my charge 3
01-02-2019 17:51
01-02-2019 17:51
I’ve done the smiley face/8 sec hold. No pink arrow appears. It syncs fine but won’t “pair” with my iPhone so I can get texts and all day sync. Any suggestions for that? Worked fine when I got it 7 days ago for about 48 hours and now not paired.
Best Answer01-02-2019 17:56
01-02-2019 17:56
I tired this and it worked to get my device paired again
Best Answer01-02-2019 18:00
01-02-2019 18:00
I just received this piece of crap,wont work, wont set up wont do anything. sending the crap back. Total waste of time.
01-02-2019 18:13
01-02-2019 18:13
The pink arrow is on your app. Not on the watch. It should say “ update available” on your app when you try to sync
Best Answer01-03-2019 05:06
01-03-2019 05:06
Best Answer01-03-2019 06:46
01-03-2019 06:46
any tips on getting the thing to connect for the very first time? just got it, and i can't get passed the 4 digit code stage. it won't go rather than "connecting to fitbit". im assuming i need it to connect initially for the firmware update to be available, but i can't seem to get it there. cant connect via desktop with this model, only mobile app. ive tried 3 different devices, so im sure the firmware is the issue, but how to fix it with no connections?!
01-03-2019 09:36
01-03-2019 09:36
Best Answer01-03-2019 17:19
01-03-2019 17:19
Best Answer01-03-2019 17:24
01-03-2019 17:24
Best Answer01-03-2019 17:25
01-03-2019 17:25
Best Answer01-03-2019 17:33
01-03-2019 17:33
Best Answer01-03-2019 17:38
01-03-2019 17:38
Best Answer01-04-2019 08:28
01-04-2019 08:28
This worked perfectly!
i only had the Charge 3 for 5 days and then it wouldn’t sync.
Just saw your tip and all’s good now.
Thank You.
Best Answer01-04-2019 11:06
01-04-2019 11:06
01-19-2019 14:55
01-19-2019 14:55
In my view, basically the Charge 3 is not compatible with iPhone or iPad. Don't know if Apple is screwing with fitbit, or fitbit just has an inferior product here, but it doesn't work.
I've done everything known to man and woman to get my Fitbit Charge 3 (I have two, they replaced one of them) and neither will not sync anymore (they did only intermittently at first). Had trouble setting them up from the beginning, but finally started tracking, but rarely recorded on the app. Now not at all. Also can't change the time through the app, and I travel from two different time zones a lot. I also can't get it to Update. I've soft and hard reset, removed tracker and re-added it, off and on blue tooth, removed app from iPad and iPhone (all these different attempts I've done NUMEROUS TIMES!!!!). Nothing works. Sending both back. I bought the Charge 3, coz I wanted the swimming/waterproof feature, yet have never used it this way since it is winter. Feel like they are forcing me to buy the more expensive watch which I really didn't want because of the extra the bulk. But now even if I go to the watches, afraid it won't work work with IOS. Pissed and put out over it.
01-25-2019 12:02
01-25-2019 12:02
This doesn’t work either
01-25-2019 12:36
01-25-2019 12:36
Best Answer01-25-2019 13:08
01-25-2019 13:08
This happened to me and I followed all the directions with no help. The only thing that fixed it was me turning off the wifi on my iphone, then it connected after the four digit code thing and all is well. I have to turn off wifi whenever I want to sync.
Best Answer01-25-2019 13:24
01-25-2019 13:24
I tried that and yet mine will continue to say "connecting to fitbit." At this point, I give up.
Best Answer01-25-2019 19:35
01-25-2019 19:35
