10-15-2018
02:47
15:06
10-15-2018
02:47
15:06
The charge 3 stopped connecting to my iPhone so now the app is worthless and I can’t track sleep or anything on the app. This happened 2 days after getting my charge 3
01-25-2019 19:37
01-25-2019 19:37
01-25-2019 19:38
01-25-2019 19:38
01-25-2019 19:55
01-25-2019 19:55
01-25-2019 20:07
01-25-2019 20:07
02-17-2019 18:59
02-17-2019 18:59
I never get a prompt on my phone to download an update. The Bluetooth is not working.
02-17-2019 19:00
02-17-2019 19:00
I’ve tried it at least 4 times.
02-17-2019 19:02
02-17-2019 19:02
Does anyone else get the bar on the Fitbit device that looks like an update? I get that but never a pink arrow on my phone
03-06-2019 09:43
03-06-2019 09:43
I cannot get my charge 3 to connect to the iphone, either. It stopped synching about 10 days ago. When I put the charge 3 into the charging cradle, I cannot access the "button." It is under the charge clamp> Help!
03-07-2019 11:14
03-07-2019 11:14
If you’re using the clip on charger, notice that one side of the clip has an opening for access to the button. I have a second different charger that does not have an opening, so if I want to do a reset, I use the clip on. When I have trouble with syncing or pairing with my iPhone, I first do the reset, (by holding the button down until you see the smiley face) then go into the phone’s Bluetooth settings and select forget device. Then I power off my phone. When I turn it back on, I go into the Fitbit app and select my charge 3, then go to notifications. It will give you the option to “pair” with your phone. Sometimes I have to do this whole process a few times before it works, but it eventually does.
03-07-2019 11:17
03-07-2019 11:17
If you’re using the clip on charger, notice that one side of the clip has an opening for access to the button. I have a second different charger that does not have an opening, so if I want to do a reset, I use the clip on. When I have trouble with syncing or pairing with my iPhone, I first do the reset, (by holding the button down until you see the smiley face) the reset has to be done while the charger is clipped on; then go into the phone’s Bluetooth settings and select forget device. Then I power off my phone. When I turn it back on, I go into the Fitbit app and select my charge 3, then go to notifications. It will give you the option to “pair” with your phone. Sometimes I have to do this whole process a few times before it works, but it eventually does.
03-08-2019 05:40
03-08-2019 05:40
03-16-2019 01:16
03-16-2019 01:16
Tried everything, read your post, followed instructions worked perfectly.
Thank you.
03-16-2019 17:48
03-16-2019 17:48
So glad I could help!
03-20-2019 17:23
03-20-2019 17:23
Wouldn't sync. I "forgot" the blue tooth connection but afterwards it would connect but not pair - thus not sync. Only way I got it to work is delete the iphone fitbit app. Reloaded the app from the app store. Then it went through the bluetooth connect and pairing process ok. This is the second round doing this. If it fails again it gets the official title as P.O.S.
05-17-2019 11:37
05-17-2019 11:37
thanks it worked for me
06-09-2019 13:03
06-09-2019 13:03
I purchased a fit bit 3 yesterday at Newark airport and tried to sync it. It got so far then stopped the update. Now it will not accept my e mail as someone else has used it🤥
06-09-2019 13:28
06-09-2019 13:28
07-07-2019 10:48
07-07-2019 10:48
I never get a smiley face.
07-07-2019 12:19 - last edited on 07-10-2020 12:23 by LiliyaFitbit
Actually I had to give up on the Charge 3. A couple of days ago the screen
went black and it is totally unusable. I have tried everything to get it
back but I've spent way too much time messing with this piece of electronic
disaster. Good luck to all you persevering Charge 3 users. I wish I hadn't
given my Charge 2 away.
"Life is a garden, dig it!"
07-22-2019 11:49
07-22-2019 11:49
Thank you for that information because it did the trick with my new Charge 3!!!!!!
