04-16-2019
13:30
11:10
04-16-2019
13:30
11:10
Hi. I have had my Charge 3 since just before Thanksgiving. A few weeks ago it went spastic for no good reason. The screen kept flashing and vibrating. I've had a tough time getting it back working. I rebooted my Charge 3 and think that maybe I have the spastic condition fixed, but the battery didn't even last 4 hours today. Prior to the episode, it lasted 5-7 days, then boom. Help....please!!!
04-17-2019 04:57
04-17-2019 04:57
Welcome on board @googette! Thanks for bringing this to our attention and for letting us know when you started noticing this to happen.
Restarts and firmware updates are demanding on the battery. I'd recommend letting your tracker to run out of battery to charge it again. Then, keep an eye on it to see how the battery goes. You can also see, Can I improve my Fitbit device's battery life?
As a side note, we recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know how it goes, I'll be around.
04-17-2019 16:04
04-17-2019 16:04
Hi! I tried your recommendation. It's been about 2-3 hours, and it appears that my battery is still full. WHAT? It was really that easy? I'm a little skeptical because I never had to do that before, but I'm happy to continue doing it if it works. If you don't hear back from me within 24 hours, please feel consider this fixed. Thank you so much for your help!!!
Best Answer04-17-2019 17:10
04-17-2019 17:10
Hi. I spoke too soon. The battery is draining entirely too fast again.
Any additional suggestions?
Thank you
04-18-2019 08:44
04-18-2019 08:44
Hi there @googette, thanks for coming back and for trying the suggestions recommended.
Since the battery on your device is still draining, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if there's anything else I may do to assist in the meantime.
Best Answer04-18-2019 08:52
04-18-2019 08:52
Thank you very much. I also noticed that since this started, the heart rate monitor is messed up. It has my heart rate in the 130-ish range all the time. Weird. I had to check my pulse and make sure it was wrong!!! Luckily for me, it was wrong.
Thanks for your help.
Best Answer04-18-2019 09:28
04-18-2019 09:28
I have the same exact problem, the Fitbit went mad, flashing and vibrating and then died, I spoke to support and we supposedly rebooted it, since then and today the charge lasted 10 hours, contacted support again and they want me to test the battery performance, even when THEY TOLD ME that it was fully charged at 5am and then died at 4pm - so if you know that isn't normal performance (like you it used to last 507 days) why do I need to waste my time further, just replace the item like you will have to do anyway.
04-19-2019 10:56 - edited 04-19-2019 10:57
Hello there @googette, thanks for coming back and for letting us know the steps worked for you!
On the other hand, accuracy of heart rate is affected by personal physiology, location of wear, and type of movement.
For tips on wrist placement and how to wear your Fitbit device for best heart-rate tracking results, please see our help article: What impacts the accuracy of my heart-rate readings?
You can also try moving your device to your other wrist.
Heart rate tracking may not work with certain accessory bands, especially if they’re loose fitting. For best results, we recommend wearing a Fitbit-branded classic or sport band during exercise. For more information, see: What should I know about my heart rate data?
Welcome on board @NainaLaw! Thanks for the detailed information you've provided in regards to your Charge 3 short battery life.
If you've already tried the troubleshooting steps they provided yesterday, please reply back to your support case letting our Support Team know the outcome. They will be more than glad to continue assisting you in this matter.
Best Answer04-19-2019 19:04
04-19-2019 19:04
Best Answer04-20-2019 10:25
04-20-2019 10:25
Hello @googette, thanks for getting back! As mentioned above, I created a support case on your behalf. If the steps provided here or the the ones you received from our Support Team didn't help, please reply to the last email you received 2 days ago. Our team will be more than glad to continue assisting you in this matter.
I'll be around if you need anything else. Have a nice day!
Best Answer04-20-2019 11:27
04-20-2019 11:27
Thanks for the reply, I did follow the instructions (still not sure why I needed to as you had a record of when it was last charged and when it died), but anyhow to satisfy your troubleshooting needs, I did all this and then it just died completely again less than 24 hours after fully charging it, so finally I'm getting a replacement in the next 5 to 7 working days. I like the fact that you try to look after customers and fix issues with a lot of questions, but when its obvious, why put customers through all this (and now over a week without a functioning fitbit) when you could have replaced it over a week ago. Anyway, its solved for now so thanks.
04-20-2019 11:44
04-20-2019 11:44
04-20-2019 11:53
04-20-2019 11:53
You've got to call them!! Repeatedly!!! I did 3 times and finally satisfied their troubleshooting needs, lots of questions and steps I was asked to follow and finally, he said "I've exhausted all the troubleshooting options, so I can send you a replacement" - that's what you need to get to. Not sure where you are based (I'm in the UK) but the guy on the phone today said something about a 2 year warranty! p.s. same here, I got mine for Christmas so around November/December time.
Best Answer04-20-2019 11:59
04-20-2019 11:59
Best Answer04-21-2019 15:57 - edited 04-21-2019 15:58
Hello guys @NainaLaw and @googette! I'm very glad to hear both of you've been issued a replacement after getting in touch with our Support Team. 😉
I'd like to give thanks for the feedback you've provided towards our product. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
I'll be around if you need assistance, it will be my pleasure!
Best Answer04-23-2019 06:01
04-23-2019 06:01
Murphy, reach out to tech support. I did. They did some back-end in investigation and determined my Charge 3 was bad. My replacement one is in it's way. It takes about a week (ish) for delivery. But it is coming. Please give them a shot. It only took maybe 10 minutes.
Best Answer04-23-2019 06:03
04-23-2019 06:03
Murphy, try reaching out to tech support. I did. They are sending a replacement. I am supposed to be getting it by Monday. Please try them.
Best Answer04-23-2019 06:36
04-23-2019 06:36
Hello there @googette, thanks for getting back and for sharing the good news! 😊 I'm very glad to hear our Support Team was able to help.
Don't forget to can set up your new Charge 3 on your currently Fitbit account without losing any previous data by following the steps below:
Best Answer04-23-2019 07:34
04-23-2019 07:34
Hi I have been having the same problem with my Charge 3 the past since this past Friday. It wont hold a charge for even 2 hrs. I was at the gym yesterday for 2 hrs and my fitbit was fully charged as of 7 am. At the gym @1015 by 11 am it completely died. I left the gym at 1230. Very frustrating as I just bought this in Jan this year.
Best Answer04-23-2019 10:06
04-23-2019 10:06
Welcome on board @ffgiggles313! Thanks for the detailed information about your Charge 3's battery life.
Please check this post and follow the tips and recommendations provided. Once you've followed then, keep an eye on your device's battery life the next couple of days and let me know if the battery keeps draining.
I'll be around, keep me in the loop.
