06-14-2020
06:15
09:48
AlejandraFitbit
06-14-2020
06:15
09:48
AlejandraFitbit
I bought my Fitbit charge 3 over a year ago. Had no problem with it until now. The battery doesn’t last an hour. I charged it was 100% and after an hour is completely drained. Also is doesn’t track my heart rate anymore. I tried to reboot it and isn’t working. What shall I do?
11-05-2020 09:49
11-05-2020 09:49
Welcome to the Community, @Viki9933.
Thanks for troubleshooting the battery and heart rate issues you are experiencing with your Charge 3. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
Best Answer11-05-2020 14:02
11-05-2020 14:02
I found if I charged it till it said 100%, then went into settings on the Charge 3 and rebooted it would then be saying 4% or 5% again. So I would charge it again. I did this over and over, maybe 10 to 15 times until it would say above 90% after the reboot. That got it back to charging properly and would hold the charge for the week like usual.
11-06-2020 09:48
11-06-2020 09:48
It's great to welcome you, @Nigel9999.
I appreciate the tip provided, I know our friend will find this really helpful.
Keep the stepping up!
