02-05-2019
07:33
11:25
02-05-2019
07:33
11:25
It froze up then started vibrating know won't hold charge
02-06-2019 06:03
02-06-2019 06:03
It's great to welcome you @Nanajl.
I am sorry to hear that your tracker isn't holding a charge. The battery in Fitbit Charge 3 can last approximately 7 days. Because battery life is affected by use and other settings, actual results may vary. Consider these tips when you want to conserve battery life:
Let me know the outcome.
02-06-2019 06:31
02-06-2019 06:31
02-07-2019 03:10
02-07-2019 03:10
Thanks for the update @Nanajl.
Since the tips provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
08-31-2019 19:01
08-31-2019 19:01
My new charge 3 stop holding a charge and now won't even hold a charge or turn off. Can I return it? I have gone thru the all the recommendations and nothing works, please help me
09-01-2019 10:27
09-01-2019 10:27
Welcome to the Forums, @Jsfp.
Thanks for troubleshooting this battery issue. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 🙂
03-07-2020 06:47
03-07-2020 06:47
I tried all the steps that were suggested and my charge3 battery will last for an hour, turn to a black screen and pulsates continuously. Help advised me.
Thanks,
Rosedolphin917
03-09-2020 12:01
03-09-2020 12:01
Hey @Rosedolphin917, welcome to the Community.
I appreciate all the efforts in trying to fix this battery issue. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
