10-19-2018
15:30
03:34
AlejandraFitbit
10-19-2018
15:30
03:34
AlejandraFitbit
Trying to pair new Charge 3 with Samsung S8. The Bluetooth sees the Charge 3 but doesn't pair successfully. I have tried 2 ways, without success:
- Restarted both the Charge 3 and phone
- Fitbit app account page, tap on set up a new device, select Charge 3, tap on 'set up your Fitbit Charge 3' and nothing happens. Any suggestions?
07-17-2020 03:43
07-17-2020 03:43
How did you force it to stop?
07-17-2020 03:51
07-17-2020 03:51
What is a good alternative?
07-17-2020 03:52
07-17-2020 03:52
What ever happened?
07-17-2020 15:35
07-17-2020 15:35
08-21-2020 11:49
08-21-2020 11:49
This is non sense!! I have been using my Charge 3 for months. Today, it fails to sync & will not update my device?? I have enabled, disabled bluetooth, I have removed the device and set up again, I have the latest update for the app? The device is next to my iPhone 8, BT is enabled, I have an active internet connection & everything is charged up.
Little bit of help would be appreciated ... and not 3 months from now...
08-21-2020 12:03
08-21-2020 12:03
I agree with you!! Customer service is horrible from what I see. Some moderator bot posts BS links. Time to take to social media and let these clowns at FitBit take a hit to their profit margins!!
08-21-2020 12:12
08-21-2020 12:12
The only other thing I would suggest, If you have not done it already is to reset the Fitbit. Also make sure the blue tooth is shut off on all your devices. Phone, PC, laptop etc. After doing the reset turn on the bluetooth on your phone and see if the Fitbit will sync. This is what fitbit tech support has me do to get mine back up and running. Pretty ridiculous to have to do this but it worked. Good luck.
08-21-2020 12:43
08-21-2020 12:43
Thanks for your reply Erich! That is the only thing I haven't tried yet. When you say "reset" the FitBit, I assume you mean hook it to the charger and hold the button for 15 seconds? I have the Charge 3.
08-22-2020 02:39
08-22-2020 02:39
08-22-2020 06:23
08-22-2020 06:23
This is not an answer. The links don’t help. Why does your product not work and what steps are being taken to solve the problems on your end? We’ve tried all the user side fixes. The problem is FitBit’s.
08-22-2020 06:30
08-22-2020 06:30
I agree. The links are worthless. I’m heading to social to spread the word about this crap.
08-22-2020 07:25
08-22-2020 07:25
Yes follow the procedure for resetting when attached to charger.
08-22-2020
07:31
10:24
SilviaFitbit
08-22-2020
07:31
10:24
SilviaFitbit
We have tried every fix several times. None work. Tired of the same suggestions over and over and over. Fitbit needs to fix their issues or refund our money.
Moderator Edit: Word choice
10-26-2020 10:39
10-26-2020 10:39
Same here, they just say mine is out of warranty, I guess then I they don't trust the watch to work longer than the warranty's length of coverage
11-12-2020 09:56
11-12-2020 09:56
Solved for me:
On Charge 3: Settings-About-Clear User Data
On Fitbit phone App: Tap the Today tab, tap your profile picture, Tap Set Up a Device, Choose Charge 3, Choose "Replace your Fitbit Charge 3". Follow further instructions.
Yes, you will lose all your previous data, but for me none of other recommended options worked.
11-12-2020 14:21
11-12-2020 14:21
11-19-2020 12:28
11-19-2020 12:28
This worked for me after two years of no use!!!
12-30-2020 12:58
12-30-2020 12:58
Just like all of your other suggestions, this does not deal with the problem nor does it resolve any problems, it just sends you in circles. If you had any real answers why not post it here up front instead of sending us chasing after link after link?!
12-30-2020 13:09
12-30-2020 13:09
Yep, after I fixed it once it didn't happen again, but when I first got the watch it happened like 12 times. I don't know what I did that seemed to "permanently" fix it to be honest.
So for anyone who comes to read this thread after all these years, I got rid of my Fitbit and went with Garmin.
Number one, I don't want to own any health hardware that is owned by Google. Google doesn't need my health data in addition to reading my email and gleefully destroying the world, thanks.
Second, my Garmin has not failed even ONCE in 3 months now. The app is great, has all the same features and the watches are frankly much nicer.
Fitbit needs to get out of being acquired by Google and kick up their quality or they're going to get eaten.
01-06-2021 03:02
01-06-2021 03:02
Erasing the data on my fitbit tracker has worked for me too!
