08-01-2019
06:30
10:55
08-01-2019
06:30
10:55
I've read every article and forum about this topic. I've tried every single suggestion for fixing it including turning on every notification in the app and phone setting, resetting Bluetooth, all-day sync is on etc. My Charge receives calls but never text messages. I have an iPhone if that matters.
I saw a forum that the charge 2 had this issue, but I was hoping the 3 would work considering it is supposed to notify messages and it's been 2 years since the company was aware of this issue.
My old Alta use to receive them. Any help is appreciated.
08-02-2019 06:43 - edited 09-04-2023 05:50
Welcome to the Community Forums @leigh11! Thanks for all the steps you've tried so far in order to solve the issue with the text messages not coming through your Charge 3. Nice way to go!
Since your Charge 3 is still not getting your text messages, please try the following:
If the steps suggested above don't work, please follow the troubleshooting steps provided in the help article: My Fitbit device isn't receiving notifications from my phone.
By the way, may I have the name of the text message app you're trying to get notifications from?
Best Answer08-06-2019 07:35
08-06-2019 07:35
@MarreFitbit The pop up never appeared when I went into Notifications.
Best Answer04-21-2020 09:33
04-21-2020 09:33
I had the same issue with a brand new one I just bought. I think I may have had my messaging app not notifying correctly. Things I had to do were to completely remove my app too for the Fitbit. Clear the device from Bluetooth, remove from your Fitbit account, delete app, restart the fit bit( you have to have it plugged in and hold the button until the while line is all the way across the screen) if you let go too soon it stops the rest and just gives the smile and turns back on. After doing all that get the app again and try connecting. The prompt to pair will appear only in the Fitbit app that I saw. So after you hit the first pop up to go into the settings go back to the app. You should now finally be linked. Note your messenger must have the “notification banner” option selected this is the type of banner that will show on the watch. Hope this helps, I know it’s a pain but don’t give up. It should work at least with an iPhone.
Best Answer04-20-2021 13:21
04-20-2021 13:21
I did all of this and it still won’t work.
Best Answer04-20-2021 20:20
04-20-2021 20:20
I tried all that. Unpaired and repaired, changed notifications, made sure background data was on, power cycled the fitbit. It's a wee bit frustrating
