12-28-2022
12:26
09:37
12-28-2022
12:26
09:37
Charge 3 won't sync and time is incorrect. Restart doesn't change anything
12-29-2022 09:38 - edited 06-23-2023 11:29
Hello there, @SteveRS55. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 3.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with.
Since you mentioned you're having syncing difficulties, please see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
