10-13-2021
12:25
12:29
CindyMFitbit
10-13-2021
12:25
12:29
CindyMFitbit
My Fitbit used to show the time when I raised my arm to look at it - not anymore! Now I have to push button to view!
Help!
Moderator Edit: Clarified subject and formatting
10-13-2021 12:43
10-13-2021 12:43
Hi @Bracken7 Nice to see you here.
Thanks for the details shared in your post. I recommend making sure that the Sleep Mode option is disabled on your Fitbit Charge 3. When the sleep mode setting is on:
To turn off Sleep mode: Press and hold the button, and swipe left to access the quick settings screen. Tap Sleep to turn it on or off. When you turn off the setting, the icon appears dim with a line through it.
Hope this helps.
10-13-2021 12:43
10-13-2021 12:43
Hope this helps.
10-14-2021 07:06
10-14-2021 07:06
10-14-2021 07:42 - edited 10-14-2021 07:43
It was a pleasure @Bracken7.
I hope it was helpful for you. Have a nice day!
