08-25-2019
13:08
10:40
08-25-2019
13:08
10:40
I've had this a week and it's worked alright apart from struggling to find my device to sync, but now it has just turned off and I can't get it to stay turned on unless it's plugged into charge.
It does have enough battery because its been on or around 85% all day now.
I have tried the reset however the smiley face just appears and now its gone back off again until I have it plugged into charge.
Any advice?
08-26-2019 06:51 - edited 08-26-2019 06:52
@Jack.Stirling Welcome to the Community Forums. Thanks for already restarting your Charge 3. Nice way to go!
Please charge your device at least 1 hour (even if it has enough power to be on). Then, perform a long restart by following the steps below:
I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Let me know if there's anything else I may do to assist you in the meantime.
Best Answer07-26-2020 02:43
07-26-2020 02:43
I tried all that... the cleaning... the different ports... the rebooting... even wiped it clean with a reset... but still the moment I take it off the charger... out... its really new... feels like I wasted money... its frustrating.
09-09-2021
12:38
14:06
BraulioFitbit
09-09-2021
12:38
14:06
BraulioFitbit
I’ve been having this exact problem with my Fitbit Charge 3 as well. I’ve followed everything step by step, and after recharging it, it acts as if it’s dead and I have to repeat the process. To be exact, I’ll write down everything I do step-by-step as per were the instructions given to restarting the Fitbit Charge 3.
1. Connected the device to the charging cable.
2.Held both buttons for 15 seconds.
3. The device did not show a battery icon. Instead it did one long buzz, showed a loading bar, and proceeded to shortly buzz 6 times as the bar loaded.
4. The device does not turn off, and proceeds to stay on the loading screen between 5 to 10 minutes. First time it took longer.
5. The device then shows the Home Screen and the Battery Icon is flickering as if it’s dead. When swiped up to check on the battery %, it either showed a 0% or — icon.
6. Removed the Charge 3 from the charger, the screen goes blank. Proceeded to put it back on and a smile appears on the screen.
7. The screen goes back to the Home Screen and the battery is flashing dead. If I go to swipe up to check the battery %, it again shows 0% or the — icon.
8. I reconnect the Charge 3 to the mobile App. The App shows it’s at 85% and there’s nothing amiss. I can change the clock, etc., while it’s still on the charger.
9. I went to check the battery % on the Charge 3 and it shows 100%, despite the App showing 85%.
10. I take the Charge 3 off the charger and it completely shuts down. The App then gives a giant Error screen.
Is anyone else having this problem? Is it a defect? Please advise.
Moderator Edit: Formatting and merged replies
Best Answer05-19-2022 09:27
05-19-2022 09:27
I am having the exact same problem with my Charge 3. Does anyone have a fix?
