04-21-2023
11:47
12:24
AndreaFitbit
04-21-2023
11:47
12:24
AndreaFitbit
My Charge 3 Fitbit keeps randomly vibrating and it is draining the battery! I've tried restarting the device but it never turns off, no matter how long I hold the button down.Help!
Moderator Edit: Updated subject for clarity.
04-22-2023 12:28
04-22-2023 12:28
Welcome to the Fitbit Community, @CrystalSantos. I'm sorry to hear that your Charge 3 doesn't stop vibrating and thank you for letting us know that you have tried restarting the device but it doesn't turn off.
Please confirm that you also tried the long restart with these instructions:
05-03-2023 01:16
05-03-2023 01:16
If your tracker is vibrating randomly, I recommend restarting it by doing the following: Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger. Clip the other end of the charging cable to the port on the back of the tracker.
A large volume reduces battery life. Use guided breathing sessions less frequently. Multiple sessions per day may reduce battery life. If you have many silent alarms set, consider deleting some.
Regards,
Will
