04-14-2019
13:40
11:08
04-14-2019
13:40
11:08
Screen flashes continuously from clock face to notification/screen wake and vibrates. Holding button down does not restart and unable to get to reboot functionality.
04-15-2019 04:50 - edited 04-15-2019 04:53
Welcome on board @sgamper2007! Thanks for trying to restart your Charge 3 in order to solve the issue with the screen. Nice way to go!
I'd like to confirm you followed every single steps provide below to properly restart your device:
If the restart doesn't work, please try changing the clock face to a different one to see if this brings back the display to work properly. As long as your tracker syncs (you can check this on the app) you can change the clock face even if the screen frozen or stuck.
I'm looking forward to your response.
04-15-2019 16:19
04-15-2019 16:19
04-17-2019 07:59
04-17-2019 07:59
Hi there @sgamper2007, thanks for coming back and for trying the recommendations provided.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Please let me know if there's anything else I may do to assist in the meantime.
Best Answer04-29-2019 17:25
04-29-2019 17:25
I am having the same issue now my fitbit will not turn on at all and I got mine for Christmas
Best Answer05-09-2019 07:57
05-09-2019 07:57
My Charge 3 started experiencing the same problem last night. It would vibrate intermittently and switch to one of the other screens (?Wake/Notifications?). This AM the battery was depleted because of all of the vibrating, etc overnight. I plugged it into the USB, let it charge, and tried a reset. However, the side button is no longer working. My Charge 3 won't reset, and I can't even use the button to move back through the screens. I've also tried changing the clock face. Still nothing. The button is still not working.
05-09-2019 09:21
05-09-2019 09:21
05-15-2019 11:50
05-15-2019 11:50
I am having the same issue have charge 3 screen is vibrating and constantly flashing between clock and screen wake/notifications screen , restarted charge 3 changed clock face but no luck my fit bit is less than 4 months old ! 😞 help!
Best Answer05-15-2019 11:51
05-15-2019 11:51
What was the solution ?
Best Answer05-15-2019 12:01
05-15-2019 12:01
I followed up with support via Twitter. They opened a support case for me, and since my Charge 3 was still under warranty, a replacement is on its way to me.
Best Answer05-15-2019 16:50
05-15-2019 16:50
Best Answer06-01-2019 18:24
06-01-2019 18:24
My charge 3 is also vibrating and flashing constantly. I have tried rebooting it using the suggested method multiple times, and it continues to flash. On this last attempt it froze on the Screen Wake/Notifications screen and is no longer responding. Because the screen was continually flashing and unresponsive I was unable to manually reboot.
Best Answer06-02-2019 04:49
06-02-2019 04:49
Best Answer06-02-2019 11:03
06-02-2019 11:03
Best Answer06-28-2019 09:21
06-28-2019 09:21
Hi support.
My wife charge 3 also have the same problem. The button is not functioning. Please help.
Best Answer06-28-2019 10:06
06-28-2019 10:06
Best Answer06-28-2019 19:36
06-28-2019 19:36
Thanks for the respond. I will contact support.This thing didn't last 4 months....
Best Answer06-29-2019 02:04
06-29-2019 02:04
Best Answer06-29-2019 12:01
06-29-2019 12:01
Best Answer11-12-2019 08:22
11-12-2019 08:22
My Fitbit charge 3 is constantly vibrating& I can’t move anything to see the different settings,it’s now on charge all that’s on the screen is a straight line
