05-13-2019
05:45
11:08
05-13-2019
05:45
11:08
My charger 3 won't stop vibrating and flashing Wake Screen Notification. Did this for an hour yesterday and woke me up again this morning.
04-22-2020 07:31
04-22-2020 07:31
I too have done everything asked of me, but nothing stops it from vibrating and changing screen. I am going to wait until my new charger comes before I bin it totally. I mean, I sent away for a new $15 charger as I figured not much money to "waste" if it wasn't that. Then I saw all of the issues with the Charge 3 on this forum. Figured I have wasted my money, but ..... never know my luck. I am the same as you - different manufacturer as I have lost confidence with the Charge model. Even the 4 sounds like there are hardly any changes, so will the fault go with that ?? Not willing to risk it. But when it worked, my wife loved it. My old "Blaze" still works well, so happy with that - touch wood.
Good luck.
Best Answer05-08-2020 12:10
05-08-2020 12:10
This is t working for me . Can someone help me?
Best Answer05-09-2020 06:03
05-09-2020 06:03
After over a month of trying, I ended up just buying a new one on sale 👎
Best Answer05-09-2020 09:00
05-09-2020 09:00
Best Answer07-02-2020 08:02
07-02-2020 08:02
I have tried this at least three times and it has not fixed the issue. The screen keeps flashing and it is vibrating very quickly. When I perform the steps listed in the reset, it acts like it has worked until I unplug it from the charging cable, then the vibration and flashing starts all over again.It was fine until I attached the charging cable due to a low battery.
Best Answer07-03-2020 17:59
07-03-2020 17:59
Best Answer07-06-2020 09:32
07-06-2020 09:32
Same problem here, and this is my THIRD defective Fitbit Charge 3 - first two were also defective, wouldn't stop flashing and buzzing even after resetting numerous times. Sometimes the "smiley face" would appear, other times no response. Called support and they took me through the longer reset (15 seconds) - still didn't work. They are replacing it again (FOURTH one), but since the warranty does not reset with the replacement I'll probably be out of luck next time.
Best Answer07-11-2020 16:56
07-11-2020 16:56
Hi. I bought my fitbit charge 3 in January 2020 and within the last hour, it started vibrating and flashing through between the clock face and the notifications screen. I have rebooted it based on the advice in this forum but it won't stop flashing. Do I request a new one or is there something else I can do?
Thank you!
Best Answer07-11-2020 17:44
07-11-2020 17:44
Best Answer07-11-2020 18:34
07-11-2020 18:34
Best Answer07-11-2020 22:58
07-11-2020 22:58
Best Answer07-12-2020 07:11
07-12-2020 07:11
Best Answer07-14-2020 17:36
07-14-2020 17:36
I tried the reboot suggestion with the charger. It started flashing more often. Strangely, under settings I do not have a reboot option. Is there anything else that I can try?
Best Answer07-14-2020 19:18
07-14-2020 19:18
Best Answer07-15-2020 06:11
07-15-2020 06:11
Thank you!!
Best Answer07-15-2020 07:03
07-15-2020 07:03
How do I go about getting a new one? While the flashing and buzzing has stopped, it's not tracking as well as it used to and doesn't hold a charge as long.
Best Answer07-15-2020 07:29
07-15-2020 07:29
Best Answer08-19-2020 08:20
08-19-2020 08:20
Having the same issue. Tried the directions and I didn't do anything. I am unable to access the setting icon to reboot it because it won't even go there
Best Answer08-19-2020 08:49
08-19-2020 08:49
With me it turned out that it was probably caused by salt water. Both times it happened after swimming in the sea, and both times it got replaced. Now I take it off before swimming in the sea. Normal water is okay.
Best Answer08-19-2020 09:26
08-19-2020 09:26
