Charge 3 won't stop vibrating and won't hold a charge
my fitbit was vibrating constantly, so I restarted it. That worked for about a week or two, then it did it again. I restarted it and it seemed fine, but it would only hold a charge for about 6 hours. Now, I can't get it to work at all.
2 REPLIES 2
Mine is doing the same thing, constantly vibrating, several line across the screen, three hard resets and now it won't hold a charge if I can get it to act normally. Right now it has a black screen with a white line and it's connected to the charger.
And no, there are no updates available.
Hi there @Stater91 and @Chavayea, welcome to the Community Forums. Thanks for the details provided and for taking the time to troubleshoot your Charge 3 trackers prior to contacting us.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
