11-30-2018 08:04 - last edited on 11-17-2020 14:34 by MatthewFitbit
I've had my Charge 3 for about three months. The swipe feature no longer works? I can't swipe up or down or to the left. Any thoughts? Thank you.
01-12-2019 12:17
01-12-2019 12:17
@hbuettner, I wonder if you're in the wrong section of the forum... this discussion is related to Charge 3 Fitbit device that has only 1 haptic button. If you go to the main community page, you can select a relevant device. Have a great day!
01-21-2019 13:14
01-21-2019 13:14
I've tried all of this to restart my Charge 3 multiple times. Still doesn't work. Have not gotten the smiley face with any of the attempted restarts. It will let me swipe when it's connected to the charger, but stops when I disconnect it.
01-21-2019 13:16
01-21-2019 13:16
I've tried all of this to restart my Charge 3 multiple times. Still doesn't work. Have not gotten the smiley face with any of the attempted restarts. It will let me swipe when it's connected to the charger, but stops when I disconnect it. I've also tried changing the clock face.
02-01-2019 12:38
02-01-2019 12:38
Issue: I can't swipe up or down or to the left, but its still synced with your phone app.
Fix: Just change the clock face using the app. After a you see a big tick on the fitbit, swiping action works again, and the charging indicator came back too.
Did it fix yours?
Your friendly IT Tech.
02-01-2019 15:08
02-01-2019 15:08
thank you! I just had the same problem and all is well again! 🙂 Love that smile!
02-04-2019 08:56
02-04-2019 08:56
That solved my problem too, thanks👍🏻
02-04-2019 18:56 - edited 02-04-2019 19:01
I cannot get mine to show the battery charging icon. It just vibrates. I've only had this Fitbit for three weeks. 😞
This seems to be a common problem with the Charger 3. Disappointing. If I can't get it to work, what do I do? Call support? Do they send a new one?
02-05-2019 16:41
02-05-2019 16:41
Thanks so much do the tip, it worked perfectly. Though I was going to have to buy a new fitbit! Thanks.
02-05-2019 16:54
02-05-2019 16:54
02-19-2019 04:12
02-19-2019 04:12
Great solution to my Fit bit 3 not swiping.
02-20-2019 10:39
02-20-2019 10:39
If it sycns With the phone use the Fitbit app change to a different clock face, I did this after after my swip stopped working on the default clock face.
Mine was Charing up even tho it didn't show it on the Fitbit screen.
I have set my clock face to the Fitbit 2 face and it been working great since.
02-20-2019 13:46
02-20-2019 13:46
Yesss, I did this too and it worked. Thank you😊
02-22-2019 06:01
02-22-2019 06:01
Well, that did the trick! Thank you!
02-22-2019 16:47
02-22-2019 16:47
My Fitbit charge 3 doesn't swipe even after I restarted it. The first time I restarted it, it swiped for awhile and then stopped. This time when I restarted it, it still wouldn't swipe! It is only 2 weeks old. Do magnets affect the way they work at all as I have a magnetic clasp on the band?
02-22-2019 17:10
02-22-2019 17:10
I did that and still not swiping
03-16-2019 18:58
03-16-2019 18:58
My Fitbit won’t swi and won’t reset when I place it in the charger
03-16-2019 18:58
03-16-2019 18:58
I tried this and it still won’t swipe
04-14-2019 11:28
04-14-2019 11:28
Thanks, Fit Bit is working again. Got love the internet.
04-14-2019 16:43
04-14-2019 16:43
Thank you, this helped tremendously!
05-20-2019 08:36
05-20-2019 08:36
My Charger 3 won’t swipe. I’ve reset it according to your instructions, but it continues to be stubborn! What next? Thanks!
