01-20-2019
03:18
13:05
01-20-2019
03:18
13:05
My new Charge 3 will not let me swipe to view notifications or to view the apps that are installed on it. What should I do?
02-23-2020 00:00
02-23-2020 00:00
i was just saying what i accidentally did , i did try to re boot from something i read last night before i found this forum and i thought i had my 3 cable in but found it was not i held the button down till i saw smile face was more then 10 seconds try that
02-23-2020 00:12
02-23-2020 00:12
02-23-2020 00:26
02-23-2020 00:26
oh thats weird mine still tracked steps just i could not see them as i could not move the bits up to see them only could see on the phone when i synced it , not sure how to fix that reboot might if you can get it to do that ??
02-23-2020 05:54
02-23-2020 05:54
02-23-2020 06:01
02-23-2020 06:01
02-23-2020 22:33
02-23-2020 22:33
When it freezes you can't swipe at all no matter what way you swipe, up or down or sideways
02-23-2020 23:06
02-23-2020 23:06
02-24-2020 00:18
02-24-2020 00:18
I did I got mine working it's someone else that has a problem that doesn't quite sound the same
02-24-2020 00:21
02-24-2020 00:21
Susangreen is having trouble sounds the same but different I got mine to reset once I got home after reading this forum
03-13-2020 10:11
03-13-2020 10:11
The long restart process worked for me. Thanks.
05-06-2020 09:18
05-06-2020 09:18
Followed step by step and it worked. Thank you!
06-30-2020 16:26
06-30-2020 16:26
Drat, I did the long reset and that seemed to work, all normal swiping worked as it usually did, Then back to a frozen screen again. Yesterday I got swiping back by doing the short reset and got through to the hard reset from the settings bit, but after that, swiping stopped after about two minutes.
going to have to replace my charge 3, and I have just gone over the one year guarantee period by almost a month...drat, drat and double drat. Great Fitbit when it was Working though. Note 100% charged, so that is not the issue.
06-30-2020 21:29
06-30-2020 21:29
07-01-2020 01:28
07-01-2020 01:28
mine did it give or take 3 times has not for a while had it do a weird thing other day where i could feel the vibration if i pressed button or when i did 10,000 steps but could not see time etc on the screen but i did the hard rest when i attached it to charger i had 18 % on battery so was not sure if that may have triggered it but it should not have but the hard reset did work will see how long before it does weird stuff again if lucky it wont
07-02-2020 15:19
07-02-2020 15:19
Hey Susan yes just over the year so technically outside warranty. But I contacted fitbit through a chat session. I was lead through a couple resets. Fit bit can monitor somehow at their end. Any way the person I was chatting to confirmed my charge 3 was faulty and he set up a replacement fitbit which is being processed now. Im getting the pebble which is just the working bit not including the straps or charger. Yahoo. Very happy. Go well regard Des
