10-18-2018
00:52
15:06
10-18-2018
00:52
15:06
I have constant sync turned on but my watch hasn’t synced since Sunday despite being close to my phone.
also
I spent nearly 5 hrs in the car yesterday but my fit bit still registered 11k steps. Certainly not right, 5k might have been closer. Every day since arrival has been in excess. I have kept it on my non dominant hand but changed the setting to dominant hand to try to get it to register correctly. Still no luck. My previous tracker ( non Fitbit) was much more accurate. Very disappointed, thinking of reverting to my old one and asking for a refund.
10-19-2018 08:22 - edited 06-11-2024 08:44
Welcome on board @Newconvert, it's nice to see you here! Thanks for the steps you've taken in order to sort this out, nice way to go!
Syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
Depending your phone, these tips might make syncing easier:
If your Fitbit device still won't sync, try these steps:
In regards to the accuracy of your Charge 3, please check this post of mine to find more detailed information.
Give this a go and let me know the outcome!
Best Answer03-14-2019 09:47
03-14-2019 09:47
I have same problems. When I drive in Bay Area over mts charge 3 gives me 34 to 95 floors climbed depending on where I’ve gone. It uses gps so registers altitude, probably inaccuratelyat that. I also get double steps on trips. Etc etc. One fit bit post said to correct such errors manually! So they know there are problems and won’t fix them. My charge 2 did not have tues problems so I assume they could be fixed. Do not buy this tracker!!!!
Best Answer03-15-2019 09:04
03-15-2019 09:04
Welcome to the Fitbit Community @sfh123! There are a couple of things that may be causing your tracker to record extra floors. It's inner altimeter will calculate altitude based on atmospheric pressure. Pressure changes due to things like weather or gusts of wind may record floors. Check more information here.
Now, if the tracker continues to do this everyday; please perform a restart on it. That should certainly help you out with this.
I've seen that you got in touch with our Support Team after posting here. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer07-31-2019 06:05
07-31-2019 06:05
None of this worked for my Charge 3. I've only had for a couple of weeks so I'm disappointed that I'm having this issue. I had a Charge 2 for a couple of years with no issues that couldn't be fixed easily. I'll have to go back to my Charge 2 until this is fixed.
08-01-2019 09:47 - edited 06-11-2024 08:17
Welcome to the Community Forums @tlv106! Thanks for following the tips and recommendations provided here.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance. If your phone is supported, please follow the troubleshooting steps provided here: Why won't my Fitbit device sync?
On the other hand, if you're having discrepancy with your step count, first make sure the wrist placement settings are correct. Next, double check that you entered your height correctly. Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average.
Remember that the wrist trackers count steps depending on the movement of your arms, when you are driving or for example when your tracker is close to a fan. In these scenarios, your tracker counts steps due to the vibrations.
To get more information about this, check the article: How accurate are Fitbit devices?
Also, please note that there are 2 ways you can prevent this:
1. You can plug your tracker into the charging cable while you are driving -- the Fitbit will not count steps while it is charging.
2. You can log the driving manually by following the steps in this article
Let me know if you need further assistance, I'll be around.
Best Answer02-18-2020 09:26
02-18-2020 09:26
I had the same issue. I uninstalled the app, then reinstalled the app and it synced immediately
Best Answer02-18-2020 09:31 - edited 06-11-2024 08:15
Hello there @tric1974, welcome to the Community Forums. I'm glad to hear that you manage to sync your Charge 3 again.
Thanks for letting us know what worked for you. In case of future help, I'd recommend taking a look at the help article: Why won't my Fitbit device sync?
I'll be around if there's anything else I may do to help you.
Best Answer04-05-2020 17:01
04-05-2020 17:01
Tried all of that and it still will not sync.
04-06-2020 00:36
04-06-2020 00:36
