09-21-2020
10:21
06:06
JuanJoFitbit
09-21-2020
10:21
06:06
JuanJoFitbit
My charge 3 has stop syncing & the clock is losing time, only thing it is doing is counting steps.
09-22-2020 06:05
09-22-2020 06:05
Hi @hayl110, it's great to see you in our Fitbit Community. I'm sorry to hear that your Charge 3 is not syncing and it won't show the correct time.
Please try the troubleshooting steps that are listed in this help article. After this, sync your tracker manually and see if the time gets corrected.
Keep me posted on the outcome.
09-22-2020 18:18
09-22-2020 18:18
Didn't fix mine....
09-22-2020 18:41
09-22-2020 18:41
de-link and re-link - sync it (if you can) and click on the trash can to de-link it from phone. Then add device to add it back.
If not, is your BT going to sleep?
09-22-2020 19:01
09-22-2020 19:01
Didnt fix mine, as its no longer showing in my bluetooth listing either
09-22-2020 19:42 - edited 09-22-2020 19:43
If it's not showing in your BT list... are other BT things working w/o prob? (are you on Pie?)(what phone?)
09-22-2020 19:43
09-22-2020 19:43
I am also having this issue. So frustrating. Every since the last update, I have been unable to sync my Charge 3 and the time is 1 hour, 10 minutes behind. There has to be another solution beyond resetting both the phone and the Charge 3. I have deleted the app too.
09-22-2020 19:51
09-22-2020 19:51
I had a tracker recently that I thought had burnt out its BT but then it connected to a different phone/ROM. My assumption was that BT and fitbit on my phone were, for some reason, going to sleep, so I changed a couple things in settings which fixed the problem and it syncs on steroids. But in present situation, if
1) de-link, and then
2) factory reset as described above, and
3) re-link
changes nothing, then I am out of ideas. 😞
09-22-2020 20:00
09-22-2020 20:00
Thanks rebooting helped mine.
09-22-2020 20:03
09-22-2020 20:03
good to hear @Tcjw
09-22-2020 21:45
09-22-2020 21:45
This has started to happen with mine too, lost time yesterday and wouldn’t sync with my phone or update anywhere, managed to get it to sync with my iPad last night but now it has lost time again and isn’t updating, this is my THIRD replacement Charge 3 in less than a year with problems NOT GOOD ENOUGH
