09-30-2018
		18:38
		15:47
		09-30-2018
		18:38
		15:47
I know there are only like 3 people that have this device right now, but if anyone else that has it can check...is yours syncing ok? Mine last synced 4 hours ago and when trying to force a manual sync it wouldn’t get past “looking.” I tried the usual fixes - turning bluetooth off and on, removing the C3 from the app and my phone and attempting to re-add it, power cycling my phone...nothing works. The user manual says to press the side button for 8 seconds to reset, but all that does is bring up the screen wake/notifications toggle screen. Just issues due to it being new/unreleased, or is it possible it crapped out on me already?!
08-05-2019 18:56
08-05-2019 18:56
I haven't been able to sync charge 3 to s7 for 2 weeks fed up
08-06-2019 06:53
08-06-2019 06:53
Exact same problem here
08-06-2019 13:07 - last edited on 02-20-2020 16:00 by LiliyaFitbit
It doesn’t fix!!! It is a waste of money and I will never purchase a Fitbit again as there is absolutely no endeavour to fit obviously the design/fault with the product itself
08-06-2019 17:59
08-06-2019 17:59
I've done this loads of times it still don't work
09-03-2019 04:54
09-03-2019 04:54
fitbit charge 3 not syncing cant even setup the thing is a total waste of money !
09-03-2019 05:02
09-03-2019 05:02
Mine won't either. I set it up and it synchronised once, now it won't sync at all. Sick of it.
09-04-2019 15:41
09-04-2019 15:41
Are you going through the PAIRING process? Initially (about a year ago?) I PAIRED my Charge 3 with both my iPhone 8+ and my iPad. And was unable to sync with iPhone. My fix was deleting fitbit from Bluetooth in both iPad and iPhone and then PAIRING only to iPhone. Hope this helps.
 Best Answer09-05-2019 00:10
09-05-2019 00:10
No, The device IS paired with the laptop only but still won't sync. I've tried to un-pair from the laptop then sync with phone sync, didn't work so tried with ipad, that didn't work either. The last replacement I only paired with the laptop, it's still paired but won't sync. Thanks for trying to help though.
09-18-2019 01:29
09-18-2019 01:29
I have had the C3 for 12 days and tried 'EVERYTHING'.
To get to the Reboot Device it is :-
From the clock face swipe left 3 times see Weather and Settings Tap Settings
See Brightness/Vibrations swipe up until you see ABOUT Tap About
See VERSION & REGULATORY INFO swipe up and FIND.... Clear User Data and
Reboot device
I have tried it. only success was to get one sync and then nothing, day after day
I have revert to paper and pen. At the end of each day make a note of your Stats. No help with Sleep Track though which is what I really wanted. It says Sleep not tracked on the Wristband. I had some issues with a Charge 2 but it did work most of the time until the face cracked and was 'unrepairable' ... under guarantee!!!! a joke product really as it takes up so much time and raises my blood pressure so not really a health helper.
09-18-2019 12:09
09-18-2019 12:09
 Best Answer09-18-2019 12:30
09-18-2019 12:30
Mine has definately crapped out, more accuratley my 2nd one in 4weeks...Tried the factory reset but no joy, have decided the Charge 3 is just a pile of poo
09-19-2019 01:57
09-19-2019 01:57
I think I'm on my fifth replacement now. I've spent hours and tried everything, totally unsatisfactory to expect buyers to do this. The last two synchronised once then never again whatever I tried. I'm thinking of setting up a Facebook/Twitter page for people who are unhappy with this product. Fitbit should recall the C3 and refund the money. Disgusted!
09-19-2019 02:12
09-19-2019 02:12
That is a great idea. Trading Standards or BBC Watchdog or the like. They are not Fit for Purpose. End of!
09-19-2019 03:05
09-19-2019 03:05
09-19-2019 03:11
09-19-2019 03:11
Great score - 11,800 messages with only 2,800 positive replies - Star! (or just the usual level of support from this company)
 Best Answer09-19-2019 07:40
09-19-2019 07:40
I’m sorry to hear you are having so much trouble with your Fitbit charge three. I don’t mean to be harsh but if this is your Fifth replacement, The problem seems to be on your end. Possibly a network issue. I’d advise you to either move on with a new tracker or wait for a Fitbit charge 4.
 Best Answer09-19-2019 08:44
09-19-2019 08:44
09-19-2019 09:50
09-19-2019 09:50
It worked well and synchronised every time for the first few months and until fitbit update. I've tried syncing to my laptop, mobile and ipad none of which works. I've followed all advice from fitbit to the letter with no joy. The device is not fit for purpose, no way would I waste more money with this company!
09-19-2019 09:54
09-19-2019 09:54
 Best Answer09-21-2019 00:23
09-21-2019 00:23
