09-30-2018
18:38
15:47
09-30-2018
18:38
15:47
I know there are only like 3 people that have this device right now, but if anyone else that has it can check...is yours syncing ok? Mine last synced 4 hours ago and when trying to force a manual sync it wouldn’t get past “looking.” I tried the usual fixes - turning bluetooth off and on, removing the C3 from the app and my phone and attempting to re-add it, power cycling my phone...nothing works. The user manual says to press the side button for 8 seconds to reset, but all that does is bring up the screen wake/notifications toggle screen. Just issues due to it being new/unreleased, or is it possible it crapped out on me already?!
09-26-2019 08:09
09-26-2019 08:09
No, I do not work for Fitbit.
I have tried “All Day sync” and fiddling with the other options.
09-26-2019 08:28
09-26-2019 08:28
I was referring to Kaisercat's comment (True it is confusing at first but I think the overwhelming majority have learned to use it and like it. I am sure Charge 4 will have less problems to work out.). From what I can see a hell of a lot are having problems with it. No way would I buy from fitbit again!
09-26-2019 08:32
09-26-2019 08:32
09-26-2019 08:47
09-26-2019 08:47
The attitude shown from Fitbit is enough to put me off buying another device. An enormously lengthy and frustrating process, I would not voluntarily do so again. When the Charge 3 fails, bye bye!
09-26-2019 08:53
09-26-2019 08:53
Ya Mark all day sync is a cool option but it is a better burn. For me it makes my tine to recharge about a day earlier. But every now and then I will enable ALL DAY SYNC which is helpful if you are going out walking and have a difficult time reading the watch display — just whip out your smartphone for you stepcount!
09-26-2019 09:02
09-26-2019 09:02
Hi Giggling, No I don’t work for fitbit. I think I first wrote that this device shouldn’t have this many problems at first. All the people I come into contact wearing a fitbit really enjoy wearing theirs. At least I think they enjoy it.
09-26-2019 12:13
09-26-2019 12:13
09-26-2019 12:16
09-26-2019 12:16
09-28-2019 02:38
09-28-2019 02:38
10-09-2019 05:56
10-09-2019 05:56
I don't work for Fitbit, but have been a customer for years. I'm on my second C3 and am now having the sync issue. Nothing I've tried has solved the problem. I'm so disappointed. Even my watch time is off...
10-09-2019 06:50
10-09-2019 06:50
The time goes off when you turn off and on to try to sync. If it doesn't sync the clock won't be corrected. They know there's a problem, I've had many replacements now and they sync the first time then not again. I'm am in discussion to return the thing now for a refund. I really hoped they'd solve this problem but sadly not.
10-10-2019 02:45
10-10-2019 02:45
10-10-2019 03:00
10-10-2019 03:00
Think I'll try a different make altogether. My fella's got Garmin which works well but needs charging more often.
10-10-2019 07:18
10-10-2019 07:18
Good point ETO. I think FITBIT tried to put so much coolness and ease of use into too small a device. Too bad of C3 uses are used as their beta testers. The C4 will be much improved I’m sure. I use my C3 only for step count and use my iPhone to look at the # steps when outside. I have everything else shut off. C3 does have a slightly better battery than the C2. I get 7 full days easily with 10-15% to spare.
11-02-2019 01:46
11-02-2019 01:46
I have this trouble all the time & getting really fed up with it all. I’ve done everything like you have done. Never can I get notifications. I see that they are saying that the updates are messing with the working if the fitbit charge 3 & they’re working on it to find a solution but hope they hurry up
11-02-2019 02:09
11-02-2019 02:09
It's the Fitbit update that caused the problem. They say they're in talks to rectify the problem but I got fed up of waiting. I've had 6 or 7 replacements (so many I've lost track) three of which had other things wrong with them. I've finally returned it and am awaiting a full refund.It's not fit for purpose as it is now. I feel for the support staff, they've always answered me politely and responded to my complaint, it's the device that's at fault.
11-02-2019 04:53
11-02-2019 04:53
11-02-2019 15:41
11-02-2019 15:41
Hey Giggles, 6 or 7 replacements? As soon as GOOGLE takes over, I’m sure your problems will be solved with your FITBIT!
11-02-2019 15:44
11-02-2019 15:44
11-02-2019 15:46
11-02-2019 15:46
Hey DAVID,
Soon GOOGLE will be in charge so you might h@ve better results!
