09-30-2018
18:38
15:47
09-30-2018
18:38
15:47
I know there are only like 3 people that have this device right now, but if anyone else that has it can check...is yours syncing ok? Mine last synced 4 hours ago and when trying to force a manual sync it wouldn’t get past “looking.” I tried the usual fixes - turning bluetooth off and on, removing the C3 from the app and my phone and attempting to re-add it, power cycling my phone...nothing works. The user manual says to press the side button for 8 seconds to reset, but all that does is bring up the screen wake/notifications toggle screen. Just issues due to it being new/unreleased, or is it possible it crapped out on me already?!
12-10-2018 18:28
12-10-2018 18:28
Best Answer12-10-2018 18:35
12-10-2018 18:35
Best Answer12-10-2018 18:47
12-10-2018 18:47
I am having the same problems. I have only had my c3 for a couple of months now I can't get it to repair or sync. My husband has a blaze with no problem. Ugh!
Best Answer12-11-2018 05:00
12-11-2018 05:00
Best Answer12-11-2018 05:04
12-11-2018 05:04
Best Answer12-11-2018 05:08
12-11-2018 05:08
Best Answer12-11-2018 05:20
12-11-2018 05:20
This is my 3rd Fitbit also and I'm gong to take this one back. and going back to using my ALTA. I'm tired of trying to get it to work, what a waste.
Best Answer12-11-2018 06:02
12-11-2018 06:02
Charge 3 Fitbit won’t sync on my iPhone or iPad. Have turned off both devices to reset but neither device will sync once devices turned back on
Best Answer12-11-2018 06:05
12-11-2018 06:05
Best Answer12-12-2018 02:42
12-12-2018 02:42
Thanks so much. I had to turn off my bluetooth for hours and when its back on, the heart rate didnt show on the app. Its really annoying, especially problems with connectivity. I think when the newer fitness devices come along, i will be so done with fitbit.
12-13-2018
08:15
07:38
12-13-2018
08:15
07:38
Hi guys, hope you are doing fine.
I appreciate all the efforts in trying to fix this issue. If you are having issues syncing your trackers, I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
Now if the issue is directly with pairing, follow the ones in the help article Why can't I set up my Fitbit device?. And for all this, make sure that your phones are compatible mobile devices.
See you around. ![]()
Best Answer12-13-2018 08:19
12-13-2018 08:19
Has this thread been shown to the developers? This isn't all user error. There are legitimate issues with the Fitbit consistently communicating with our phones. Re-syncing the device and erasing all records it's NOT the solution because it always comes back.
12-13-2018 13:38
12-13-2018 13:38
12-13-2018
14:00
03:34
AlejandraFitbit
12-13-2018
14:00
03:34
AlejandraFitbit
Thank you. Fitbit Customer Support was able to sync the Charge 3.
Best Answer12-13-2018 14:09
12-13-2018 14:09
They will never fix this garbage. I had to get a replacement and it lasted 7 days before sync broke again. No kind of reset fixes it, just a new watch every time. Keep calling support and put them out of business by forcing them to send you more product.
Best Answer12-13-2018 14:25
12-13-2018 14:25
Best Answer12-13-2018 14:54
12-13-2018 14:54
05:10
07:21
12-14-2018
05:10
07:21
Hello all, thanks for your participation in the Community.
I am glad to hear that some of you contacted support and they were able to help with the syncing issues. As recommended, please make sure that your phones are compatible mobile devices. Keep in mind that having a compatible phone will help to have a better connection between your tracker and it.
If you keep having this problem, I suggest taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
Catch you later. ![]()
Best Answer12-14-2018 05:22
12-14-2018 05:22
If I keep having this problem... An article that doesn't address the problem is the best bet? Sweet. Good to know it's a brand new $150 with no support.
12-15-2018 07:25 - edited 12-15-2018 07:26
@SunsetRunner wrote:Thank you. Fitbit Customer Support was able to sync the Charge 3.
Just wondering if yours is still syncing? When I called customer support they said it was an issue with iPhone 8 and I had to wait until an app update come out addressing this issue.
