11-26-2018
15:11
14:34
11-26-2018
15:11
14:34
Hi,
i've had my Charge 3 for about 6 weeks now and every week I have issues with syncing. I've actually uninstalled the app and reinstalled every week. It won't sync properly with my Samsung Galaxy 9+ phone or with my laptop. I'm about ready to ditch this for another model. Wish I hadn't given my Charge 2 away!
01-16-2019 09:16
01-16-2019 09:16
@SunsetRunner, are you trying to pair from phone or from Fitbit app? Pairing from Phone settings is not going to work (and is likely to cause incorrect passcode error). Please, restart both Charge 3 and Phone, and try to pair them again (Charge 3 should be connected to the charger and plugged in). Also, phone should be set to 'discoverable' mode to be visible by Charge 3. Please, let us know how it goes!
Best Answer01-16-2019 15:22
01-16-2019 15:22
Best Answer01-16-2019 15:45
01-16-2019 15:45
@SunsetRunner, so sorry to hear about it... You may want to contact Customer Service for additional troubleshooting options. If something is wrong with the device, they should be able to help you with the exchange (unless it's easier to exchange it at the place of purchase)
Best Answer02-04-2019 11:05
02-04-2019 11:05
Thanks for the tip. I think this was the solution I was looking for. I removed all my old devices and it seems to work much better now. Hopefully it stays that way!
@JKrej wrote:I finally got mine to work after many different attempts. The key was that I had to force it to stop syncing on my old Charge 2 and delete that device from the Fitbit app
Best Answer02-04-2019 11:33
02-04-2019 11:33
Best Answer03-06-2019 12:07
03-06-2019 12:07
I'm now having this issue would not sync tried everything so thought I've lost over a weeks data as it is ill unpair and start again band now it won't connect says connecting then doesn't pick it up anyone able to help?
Best Answer03-13-2019 03:18
03-13-2019 03:18
New Charge 3. Will not sync to Samsung Galaxy S9.
03-13-2019 03:24
03-13-2019 03:24
I'm very disappointed to find I cannot sync my new charge 3 to galaxy s9. Is there anything I can do before I pack it up and send it back?
Best Answer03-13-2019 06:13
03-13-2019 06:13
Best Answer03-13-2019 06:30
03-13-2019 06:30
Best Answer03-13-2019 18:20
03-13-2019 18:20
@SylviaMC, also please check that Fitbit app has all the permissions granted in phone settings and power saving mode is disabled.
I'd also recommend this help article - see if you can identify potential issue. I've been using S9 since November of last year and haven't had any syncing issues (besides small hiccups that can be resolved easily). Hope you can make it work!
03-19-2019 12:27
03-19-2019 12:27
I just got a fitbit charge 3 after using a charge 2 for over a year with no problems. Immediately syncing problems.. I have a Samsung s9+. I removed the charge 2 profile from phone bluetooth and from fitbit -- finally got them to re-connect.
Never had problems with the charge 2 so it HAS to the charge 3 that is the problem.
Reading through the help you are supposed to be able to have 2 different devices configured and reporting to fitbit--
What is the problem? Rebooting- reinstalling are all just work arounds. Is there a firmware fix in the works?
Best Answer03-19-2019 16:39
03-19-2019 16:39
Best Answer03-19-2019 17:30
03-19-2019 17:30
Best Answer03-19-2019 18:09
03-19-2019 18:09
Best Answer03-19-2019 18:11
03-19-2019 18:11
Best Answer03-27-2019 01:02
03-27-2019 01:02
I have the same issues, this morning it has unpaired itself an now won't even repair, i am getting so annoyed with it. Any help greatly appreciated...
Best Answer03-27-2019 08:45
03-27-2019 08:45
do a re-set on the fitbit- and start all over,, I did that and it has behaved for a week now with no problems.
Best Answer03-27-2019 12:21
03-27-2019 12:21
I will do thank you
Best Answer04-03-2019 14:29
04-03-2019 14:29
