11-26-2018
15:11
14:34
11-26-2018
15:11
14:34
Hi,
i've had my Charge 3 for about 6 weeks now and every week I have issues with syncing. I've actually uninstalled the app and reinstalled every week. It won't sync properly with my Samsung Galaxy 9+ phone or with my laptop. I'm about ready to ditch this for another model. Wish I hadn't given my Charge 2 away!
04-03-2019 14:36
04-03-2019 14:36
04-29-2019 09:49
04-29-2019 09:49
Charge 3's & Samsung S9:s must be a bad fit.
Mine connects very intermittently & is annoying. My Charge 2 worked great but died.
Painful exercise.
04-29-2019 13:23
04-29-2019 13:23
I did the firmware update and the connectivity " problem appears" to have been fixed..wait till you apply the FW update .
04-29-2019 15:24 - edited 04-29-2019 15:28
I've spent so much time on this **ahem** and am totally frustrated. It sporadically connects, only way to synch is to use an old phone with app level of 2.80. I believe the 2.92 level is broke. It seemed to work fine at 2.90 on a Galaxy s8 & OK a few days on my S9 until the 2.92 upgrade {downgrade?) I get a msg up load new firmware on the Charge 3 but won't connect. Plus I get a msg that the Fitbit Bluetooth is busy..... This really stinks
Can't update if I can't connect...
Tried an older Note 4 phone (2.92) & if I get past the Fitbit Bluetooth busy pop-up, it yrys to connect but dies. Ugh
04-30-2019 03:19
04-30-2019 03:19
05-16-2019 14:47
05-16-2019 14:47
Finally someone doing some real trouble shooting, going beyond simply re-connecting the darn thing. Thanks for the lead will try this tomorrow!
05-27-2019 08:36
05-27-2019 08:36
Took forever, but I was able to connect to my S9. I had to delete my old Charge 2 from my fitbit account and phone, plus I had to move the old Charge 2 far away so the phone Bluetooth didn't see it. Then I deleted the Fitbit app and reinstalled. Rebooted the Charge 3 then connected through the app. Finally worked.
09-10-2019 01:34
09-10-2019 01:34
Was syncing fine but now don't can't find device all the time and my watch now loses time as well. I have removed app reinstalled app removed charger 3 added it again I don't think it's the phone I think it's an issue with the Fitbit any advice would be welcome I have contacted Fitbit through Facebook this is the 2nd watch I have had I can't keep removing and reinstalling. Would I be better trying to sync with a different product?? HELP PLEASE
09-10-2019 01:36
09-10-2019 01:36
Have a Samsung s9+
09-10-2019 04:25
09-10-2019 04:25
Mine synced with my phone and my tablet but now it just shows me calories burned - which is of no interest to me. Going to the "Discover" page and then Health and Fitness only exercise is shown as added, and when I try to add Sleep, Heart Rate, Hourly Steps (which were on before) it just says it requires a device with a heart rate monitor. yet the heart rate shows on the device itself.
09-12-2019 01:26
09-12-2019 01:26
09-12-2019 01:32
09-12-2019 01:32
12-14-2019 02:38
12-14-2019 02:38
my Charge3 works fine on my iPad, and on my old Samsung S5, but does not work on my Samsung S9.
Initially the Charge3 does not get listen when running a bluetooth scan, when I disable/enable bluetooth on my S9, then the Charge3 appears, but I cannot connect, I also made sure I disabled bluetooth on any other device in the area to avoid conflicts… but no luck. I guess I'll have to use my iPad to sync my data, but that means I cannot use the features of my Phone (tekst messages, missed calls, reminders, locations where I walked ..). I manage to connect my S9 with other devices (speaker, car, weight balance ..) so the root cause of the issue does not seem to be on the Phone itself, but rather a compatibility issue between both.
I hope someone takes the responsibility to investigate and look for a fix … there is a lot of competition on the market and unsolved problems will result in people choosing alternative products.
12-14-2019 15:05
12-14-2019 15:05
01-04-2020 10:46
01-04-2020 10:46
My new Charge 3 Special edition will not stay tracking my HR or my sleep, with my Galaxy S9+. The two main reasons I wear it. Looks like I'm not the only one having problems. I just returned my regular Charge 3 for the more expensive SE thinking I had a bad tracker. My Charge 2 NEVER had a problem. Why am I "upgrading" for less functions?? If this doesn't get fixed, I will never own another Fitbit. I'll go with the Garmin.
03-08-2021 09:34
03-08-2021 09:34
I agree! This is too much aggravation and too much money spent for a device that won't even sync when needed!
