09-21-2019
05:10
10:43
09-21-2019
05:10
10:43
I have upgraded to the iPhone 11 (not Pro or Max) and my Fitbit Charge 3 is no longer a recognizable Bluetooth device. I know it’s not an IOS 13 issue because it worked fine on my old phone. I have tried turning my phone off and on, turning Bluetooth off and on, rebooting the Fitbit and uninstalling and reinstalling the app. Is anyone else having this issue?
09-21-2019 06:46
09-21-2019 06:46
Do you still have your old phone? If so, make sure it doesn't have a connection to the fitbit in its bluetooth settings as this could be blocking connection to the new phone.
09-21-2019 14:39 - edited 09-21-2019 14:48
Many thanks, it works 🙂 !
Best Answer09-23-2019 11:44
09-23-2019 11:44
I am having the same issue, but with a charge 2.... i cannot get my text messages on my charge 2... i have done everything and my old phone is not connected.....any ideas
Best Answer09-24-2019 05:14
09-24-2019 05:14
One of my problems was that I was still connected to my old phone and needed to remove it but you say you aren't. My second problem was that I needed to go to the Fitbit app and in my account select my Charge 3 and then select notifications. Those weren't paired with my phone. Once I did those two things I was good to go. Besides posting here I went to Twitter and DM Fitbit support. They aren't like a live chat but will reply within the hour and were helpful.
Best Answer09-24-2019 05:16
09-24-2019 05:16
Thank you. This helped.
Best Answer01-03-2020 06:35
01-03-2020 06:35
Me too since 12/25/19
Best Answer01-03-2020 07:10
01-03-2020 07:10
Did you get a new phone? I had to unpair it from my previous phone and then it worked.
Best Answer01-14-2020 07:44
01-14-2020 07:44
New iPhone 11pro that will not connect to my old Charge 3. Traded in my old iPhone 7 so I don’t have that. Any suggestions?
01-18-2020 19:05
01-18-2020 19:05
iPhone 11 and Bluetooth issues w/ the Charge 3:
I had to delete and re-install the FitBit app, BUT I ALSO had to “remove” my Charge3 device from the app. I tired to just delete and reinstall the app, and then have the Bluetooth find the device but it wouldn’t work Once I did removed the Fitbit within the app and added it back like a new device it worked like new!! Yay!!
i wanted to add screenshots but I can’t... tap the image of a Fitbit in the top upper left of your daily activity screen.... when you get to the setting page where you’d pick a clock face etc, scroll to the bottom and select the option to “remove this charge 3”... once you do that, just set up your Fitbit like you did when you first bought it, and it run through the set-up and reconnect you. Good luck!
Best Answer01-18-2020 21:20
01-18-2020 21:20
Best Answer07-24-2020 01:21
07-24-2020 01:21
worked for me too thanks I'd deleted the tracker but not disconnected 👍🏻
Best Answer08-07-2020 13:58
08-07-2020 13:58
Hello I’m having same issue I reset it stays on for a while then disappears getting real annoyed I’ve contacted Fitbit but they no help buy new Fitbit and don’t work why sell them then can any one help it’s so frustrating
