05-11-2021
15:01
04:27
WilsonFitbit
05-11-2021
15:01
04:27
WilsonFitbit
My charge 3 stopped vibrating for notifications some months ago and now won't sync or pair with my iphone.
05-13-2021 05:11
05-13-2021 05:11
@MK-Calgary Thanks for your reply.
I appreciate your help for following the suggested steps. Since the inconvenience has persisted, my best recommendation is that you please reach out to our Support Team for further assistance. You can contact them through chat or over the phone and you can click here to get connected.
Make sure to explain the inconvenience and the troubleshooting steps you've followed, this way they can assist you from there.
See you around.
05-12-2021 04:35
05-12-2021 04:35
Hello @MK-Calgary. Welcome to the community forums!
Thank you for the detailed information. For the syncing inconvenience, I recommend visiting the following help article for tips and suggestions:
Why won't my Fitbit device sync?
Take into consideration that the Fitbit App works well with any mobile device that meets the requirements listed in this link. In addition, Charge 3 is not compatible with Windows 10 and it is required a compatible Android phone, iPhone or iPad for the syncing process and notifications etc.
For the vibration inconvenience, please make sure that Sleep Mode or Do not Disturb aren't enabled. (Actually, you can't turn on do not disturb and sleep mode at the same) but having one of them activated won't cause the tracker to vibrate when receiving notifications.
Hope this helps.
05-12-2021 06:24
05-12-2021 06:24
05-13-2021 05:11
05-13-2021 05:11
See you around.
05-15-2021 10:15
05-15-2021 10:15
Thanks. Yes I did.
05-17-2021 05:13
05-17-2021 05:13
@MK-Calgary Thanks for contacting our Support Team. I hope the inconvenience is now resolved.
See you around.
