04-16-2020
16:10
13:02
04-16-2020
16:10
13:02
Yesterday I had to install a software update for my iPhone 8 and my iPad. Since then, I can’t get my charge 3 to sync. I have tried all the strategies in the help forum including restarting my charge 3, shutting down my devices and restarting, etc. please help
04-18-2020 06:52
04-18-2020 06:52
Hi @Layla110, thanks for stopping by in the Community Forums. I apologize for the late response, due to recent events affecting our operations, we're taking longer to respond.
I'm sorry to hear that your Charge 3 stopped syncing to your iOS devices after the update. Thanks for troubleshooting the syncing difficulties prior to contacting us, I'm here to help you.
As my very first approach, I'd like you to please confirm if you've followed the troubleshooting steps provided here: Why won't my Fitbit device sync?
If so, I recommend checking the following:
- Open Settings app on phone
- Scroll down, tap Fitbit -> Toggle Location to 'Always'
- Ensure toggles next to Bluetooth and Background App Refresh are turned ON
Give this a go and let me know how it goes.
04-18-2020 07:04
04-18-2020 07:04
I have the same issue with my Charge 3. I have an iPhone 8plus, and I can’t sync at all since yesterday. I have tried all the suggestions. Restarted the Fitbit more times than I can count. Deleted the Fitbit app and reinstalled it twice: turned on and off my phone.i even tried to reinstall the Fitbit to my phone as a new device, but was unable too.
04-18-2020 07:47
04-18-2020 07:47
Same issue. Have done all the same fixes. Not syncing. Hep!
04-18-2020 07:52
04-18-2020 07:52
04-18-2020 08:26
04-18-2020 08:26
04-18-2020 13:01
04-18-2020 13:01
After I updated my IPad yesterday my Charge 3 too stopped syncing. I have tried all the suggestion to no avail. Any other advice?
04-19-2020 05:29
04-19-2020 05:29
This morning I could finally get my Charge 3 to sync to my iPad (after turning on/off Bluetooth multiple times, as well as opening and shutting the app.) It must have taken 5 minutes in total. Then when I opened up my iPhone, it too had the correct numbers on it, but that was only because the iPad was finally able to sync. My iPhone still can not find my Charge 3.
This has to be an issue with Charge 3 and iOS. Do you think they will provide a fix?
04-19-2020 09:13
04-19-2020 09:13
04-19-2020 10:20
04-19-2020 10:20
same problem with my iPad after updating
04-19-2020 11:07
04-19-2020 11:07
I am beyond frustrated! I have tried every type of fix I can find! Still not syncing! I am glad to hear I am not the only one having this issue.
04-20-2020 06:32
04-20-2020 06:32
Nothing is working on this issue of my Charger 3 not connecting and syncing with either my iPhone or iPad after software update was installed. If you would look at all of the other people complaining about the same issue, it would appear to be something that needs to be fixed on Fitbit side.
04-20-2020 07:33
04-20-2020 07:33
I have tried several times to delete the Fitbit app and reinstall it. The app will not install now! Has anyone contacted Fitbit?
05-06-2020 06:20
05-06-2020 06:20
I finally was able to fix mine. These are the steps that I took:
Good luck
05-06-2020 08:46
05-06-2020 08:46
