01-24-2019
05:25
13:05
01-24-2019
05:25
13:05
Due to blutooth sync issues / headaches with my phone / laptop I purchased the fitbit usb blutooth dongle in hopes of avoiding the sync issues with my charge 3. It worked well for the first week on my Windows 10 PC. Now we are back to square 1. Fitbit's own B.T. USB dongle will no longer sync with my Charge 3. It can't find my charge 3 anymore. Very disappointed.
01-25-2019 03:22
01-25-2019 03:22
It's nice to see you around here! If you use more than one device to sync, make sure the other device isn't nearby. If the device is nearby, turn off Bluetooth on it. For more information, see Why won't my Fitbit device sync to another phone or computer?
On Windows 10 computer:
If the set up doesn't work on your Windows 10 computer, verify the following:
If you're still unable to set up, try the troubleshooting steps below:
Give this a go and let me know the outcome!
01-25-2019 03:22
01-25-2019 03:22
02-26-2020 20:10
02-26-2020 20:10
The question was for a device without bluetooth where the person was using - or trying to use a dongle. My laptop is my syncing device. I have used the dongle in other countries and today it decided that it could not find my Charge 3. I'm not buying a new computer just to use Fitbit. I called for help and was told "the Charge 3 was not designed to use a dongle." That is odd since the answer to non-bluetooth for syncing is to use the wireless dongle. Mine plus into the computer but I guess it is wireless to the fitbit device.
Your answer is completely useless.
05-21-2020 08:13
05-21-2020 08:13
Another terrible "stock" answer from Fitbit, where they haven't even read your issue.
08-21-2021 09:06
08-21-2021 09:06
Check also whether your device has "Do not disturb" set. I found that this was what was preventing me from bluetooth pairing with Windows 10 (and other devices for that matter). I don't don't know how "Do not disturb" (which is in the tracker settings) gets set to on. I suspect it's dues to user error or accidental clicking on the device button.
08-21-2021
17:54
05:10
WilsonFitbit
08-21-2021
17:54
05:10
WilsonFitbit
I just checked all my settings and do not even find an option for Do Not Disturb, either on the Fitbit settings or the settings on either device on the account. At this point I am just hoping that all my data will still be there to sync when I get home.
I force-entered calories, other activities, and steps, but there is no way to enter flights of stairs manually. I skipped sleep altogether. I Too much bother.
I'll deal with this when I get home, not on the road.
08-23-2021
05:20
09:46
08-23-2021
05:20
09:46
Hello everyone. @hellagood Welcome to the community forums. @JeanC1 Nice to see you around.
@hellagood Thank you very much for your nice input. @JeanC1 I appreciate the detailed information. I'd like to let you know that the DND option can be found on the quick settings screen on your Charge 3. If you have questions about how to navigate your tracker, please check here.
In addition, to learn about which Fitbit data can be manually logged in the Fitbit app, please check: How do I add, edit, or delete Fitbit data and activities?
On a side note, your understanding is very appreciated, but Fitbit devices like the Ace 3, Ace 2, Aria Air, Charge 3, Charge 4, Inspire 2, Sense, Versa 2, and Versa 3 aren't supported on Windows 10 and require a compatible Android phone, iPhone, or iPad. Although you've been syncing your Charge 3 using a Dongle, it is possible that it will encounter any syncing inconvenience due to compatibility issues. For more information about compatibility, please check: https://www.fitbit.com/global/us/technology/compatible-devices.
Lastly, this thread is now closed and if you have any questions or inquiries, please post them in a new thread.
