10-07-2018
11:30
15:47
10-07-2018
11:30
15:47
11-03-2018 06:55
11-03-2018 06:55
11-03-2018 06:58
11-03-2018 06:58
You won't be able to sync at all without internet (cloud) access.
11-03-2018 10:52
11-03-2018 10:52
I just returned mine to Best Buy and probably will never buy the Fitbit brand again. Its disappointing.
11-03-2018 11:02
11-03-2018 11:02
11-03-2018 12:02
11-03-2018 12:02
Thank you for your advice it has worked a treat. Charge 3 now synced
11-03-2018 19:41
11-03-2018 19:41
I have tried. I just restart my ss note 8 .It vould sync again
11-04-2018 20:21
11-04-2018 20:21
Mine can’t sync either, I bought mine yesterday and wish I had seen these reviews earlier. It’s going back tomorrow,
11-05-2018 11:05
11-05-2018 11:05
I did a sync through my cellphone while my charge 3 was charging. The response time to sync and display my yesterday stats was improvef ... But! - I lost my clock face (WTF?) so I put the Charge 3 back on the charger cable and then set a new clock face on the 3. Seems to be fixed now and the sync is still improved
11-05-2018 13:17
11-05-2018 13:17
11-07-2018 09:50
11-07-2018 09:50
did not work for me - got all the way to entering the 4 digit code to add and could not connect multiple times - returning it to amazon.
11-08-2018 06:30
11-08-2018 06:30
Hello everyone! Sorry to hear some of you go! I'd like to give thanks for the feedback you've provided towards our product. Rest assured that our engineers and product development team use this information to further improve our products. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
I'm glad to read some of you were also to sync again. Thanks for sharing the steps that worked for you.
If needed, please see: Why won't my Fitbit device sync? and make sure your mobile phone is included in our list of supported devices.
If you have questions, let me know.
11-08-2018 06:35
11-08-2018 06:35
11-08-2018 06:46
11-08-2018 06:46
please remove me from this group chain. i havw returned the device and moved on to something different.
11-08-2018 07:23
11-08-2018 07:23
Am I going to lose the past 2 days of steps if unpaired and add new device again?
11-08-2018 07:45
11-08-2018 07:45
This is not a real solution. Why is Fitbit not responding to so many people having issues with syncing etc. after the firmware update? This is absolutely ridiculous. I've had a variety of Fitbits over the years and luckily have had no issues until the Charge 3. I think if I had had issues sooner I would never have come back to using a Fitbit again.
I am having many issues after the firmware update which include:
Spent more than an hour the other night with online help doing all of the resets, restarts, removing app, replacing app, turning off blue tooth, turning on blue tooth, turning the phone off and back on again. Was told the issue would be escalated and that I would receive and email. So far no email.
This Fitbit worked PERFECTLY out of the box for more than a week. After the firmware update all hell broke loose! I'm hoping that Fitbit is working on a solution to this as I love the Charge 3 and do not want to have to go back to the Charge 2
11-08-2018 08:00
11-08-2018 08:00
11-08-2018 09:59
11-08-2018 09:59
11-08-2018 11:22
11-08-2018 11:22
I had the same issue with my Note 9. Set it up yesterday, everything was fine, then wouldn't sync again last night or today. Read thru all the solutions and thought I'd try to just restart my phone before losing all the data from my Fitbit. Well as soon as I restarted my phone and opened my Fitbit app it had synced on its own and all data was intact! Try that before disconnecting your Charge 3 and then reconnecting, which drops all your data. Good luck!
11-08-2018 13:05
11-08-2018 13:05
11-14-2018 02:04
11-14-2018 02:04
I am having the same problem as everyone.
I specially relate with mammbs comment.
After the firmware update I started having several issues including:
- problems with syncing
- heart rate not recording
- exercise session stops automatically
- exercise shortcuts are different from the ones I had before and the ones on the app
- syncing only the steps and not sleep or exercise or heart rate.
I tried following all the steps to fix this including:
- Turning On/Off the Bluetooth and phone
- Unpairing tracker from phone and pairing it using the app
- Removing the tracker from the app and pairing it again
- rebooting the tracker and the phone
- Re-installing the app
My situation now became worse because I cannot even get my tracker on the app. It gets me until the step I have to add the pin (so it recognizes the device) to pair and after that it does not find the tracker anymore. I would like to have an urgent and immediate solution to not lose any data that is stored on the tracker. I only have the tracker for 3 weeks so I can still consider change it by another one or just return it but I very much like it and I would rather not go through that solution.
Thank you all,
João
