01-24-2019
12:03
13:05
01-24-2019
12:03
13:05
The past 3 days my Charge 3 has not tracked my sleep. It’s worked perfectly for weeks and now all of a sudden it’s stopped tracking my sleep, I haven't changed it in anyway, anyone able to help?
01-25-2019 03:13
01-25-2019 03:13
It's great to see new faces @ZoeyC1992, welcome!
If your tracker isn't registering your sleep, I recommend trying the following:
Let me know the outcome.
04-20-2019 15:47
04-20-2019 15:47
I have the same problem. It’s not my heart rate. It just isn’t tracking any kind of sleep at all. It’s like that part of the program isn’t working. I’ve done all the things listen but still doesn’t work. Any ideas? Thanks
04-21-2019 07:47
04-21-2019 07:47
Hey @Rache03117, good to see you around.
Thanks for troubleshooting this sleep issue by yourself. Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 🙂
12-07-2019 02:38
12-07-2019 02:38
hi. I’m having the same problem. My charge 3 is not monitoring my sleep. I have done the recommended steps but is still not working. Can you help?
thanks
12-08-2019 05:15
12-08-2019 05:15
Welcome to the Forums, @Charlenneo.
Thanks for troubleshooting this sleep issue. Can you please check my previous post and confirm that those steps are the ones that you have followed?.
I hope to hear from you soon. 🙂
12-30-2019 09:09
12-30-2019 09:09
I bought my daughter a Fitbit charge 3 for Christmas. It has not tracked any sleep from the start. We tried those 3 steps and it still does not work?
01-01-2020 06:57
01-01-2020 06:57
It's great to see new faces @Michele97, welcome.
I appreciate all the efforts in trying to fix this sleep issue. Since the steps provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 😉
01-01-2020 07:20
01-01-2020 07:20
Hello, same issue, but in addition HR doesn't track. When I restart the device it works for a day then stops working again. Charge 2 worked fine for several years, including on my current phone.
01-01-2020 19:01
01-01-2020 19:01
Same problem here ever since getting Charge 3 almost a year ago. In a year it has recorded maybe ten nights. When it does record it says I slept about an hour and doesn't record any sleep cycle. I've done each of the steps indicated for this post but to no avail.
01-08-2020 01:08
01-08-2020 01:08
Mine has always tracked my sleep well with heart rate and oxygen saturation too. But for the last two nights it is not giving me a sleep score saying it couldn't track my heart rate. However, when I look at my heart rate in the app it has data throughout the night.
01-08-2020 01:43
01-08-2020 01:43
On the Charge 3 go to Settings>About>Reboot Device. Also restart your mobile device (do not just put the mobile to sleep, needs to be restarted).
01-08-2020 01:52
01-08-2020 01:52
Mine is the same my daughter gave me a charge 3 for Christmas and sleep will not log or let me add to my list. I’ve reset it twice thinking that was the problem but it still doesn’t work. Can someone help me too please
01-18-2020 19:11
01-18-2020 19:11
Same thing is suddenly happening to me! My sleep history is fine, and there isn't even anything on my dashboard related to sleep. When I went to Discovery and tried to add it, it won't let me.
01-18-2020 23:53
01-18-2020 23:53
01-21-2020 22:06
01-21-2020 22:06
That sounds like a really bad product for the new decade we're in.
I haven't worn my fitbit for two months because I feel it's just not worth with the inaccuracy of the thing 😕
01-21-2020 22:07
01-21-2020 22:07
I've tried this, did not do anything. 😞
02-16-2020 09:53
02-16-2020 09:53
My Charge 2 tracked my sleep beautifully, and gave all the stages. When I upgraded to the Charge 3, everything went downhill. The introduction of a SleepScore means nothing to me, and my device almost never tracks my sleep - sometimes it will track an hour or two, with huge gaps, and when I try to edit the log, it doesn't give me detailed reports like it used to. Such a bummer. Why take a functional aspect and ruin it?
04-15-2020 08:29
04-15-2020 08:29
Weirdly enough guys I switched my Fitbit to sensitive and I slept with it on sensitive for a night (which was worse it didn’t catch any sleep at all) but then I changed it back to normal and then that night it started tracking my sleep normally again. Idk if switching it sort of reset it? But it works again. It still didn’t work correctly (didn’t show the whole night of sleep) after I updated it, which I tried -before- changing it to sensitive and back. But switching to sensitive and back to normal seemed to make it work. To do this you go to advanced settings in the Fitbit app.
04-20-2020 00:26 - edited 04-20-2020 00:28
Purchase my Fitbit just before Christmas. having the same problem as othere's on here not logging sleep and oxygen levels. have tried all the suggestions to restart the tracker with no result. Have noticed the red LEDs don't lite up.
