01-22-2021 04:06
01-22-2021 04:06
My charge started vibrating while I was wearing it then it was unresponsive. I put it on charge in case it was the battery. A smiley face showed up then when I came back to it the fitbit was burning hot. I let it cool down and have tried to reset it but nothing is working it won't turn on at all and it's still getting hot on charge.
01-22-2021 10:53
01-22-2021 10:53
Welcome to the Fitbit Community, @Rebecca686.
Thanks for the details shared in your post and for already trying to resolve the issue. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
I'll be around if you have any questions.
Best Answer01-22-2021 11:32
01-22-2021 11:32
Thank you. Its still not responding at all there's no vibration or anything to show its working and I'm scared to put it on charge it seems unsafe.
Best Answer01-22-2021 12:51
01-22-2021 12:51
Thank you for your reply, @Rebecca686.
I appreciate the additional details and recommend to not connect the tracker to the charging cable. Our Support team will do their best to help you. Due to recent events affecting our operations, our Support team may take longer to contact you. I appreciate your patience and understanding. If you're pressed for time, you can try using chat or phone to continue with this issue. Please check our Support contact options here.
I'll be around.
