10-11-2018
19:31
15:06
10-11-2018
19:31
15:06
Charge 3 got it last night was working fine all day and I looked down at my wrist it was black so I figured it was just dead ...plug it in and it won’t vibrate turn on or show me any sign that it’s charging ?!
10-16-2019 09:25
10-16-2019 09:25
This happened a few times with me... open the app and change watchfaces, change back. Sync.
Best Answer10-20-2019 01:24
10-20-2019 01:24
Hi, I've tried plugging it into computer and holding side button for 10secs. I get smiley face but then nothing. Extremely disappointing .
Trish
Best Answer10-20-2019 03:06
10-20-2019 03:06
Wife’s charge 3 won’t turn on tried all stuff from community forums still no good second one we’ve had !!! Not happy
12-29-2019
14:35
09:20
AlvaroFitbit
12-29-2019
14:35
09:20
AlvaroFitbit
Fit bit charge 3 will not turn off after reset. I see the smile face but screen goes black after the smile face. The app says it is fully charged but I can’t update the tracker or change the clock face cause it says I’m not connected to the tracker......please help!
Moderator Edit: Formatting
12-29-2019 19:25 - edited 12-29-2019 19:46
Hey Aron. Your charge3 is dead. My replacement died after a few months. You can phone Fitbit support and they will send you a replacement or you can switch to different model for half price, (inside warranty) If you have the funds for alternative model or brand, do that (keep the old straps if you go for another C3) Fitbit number for UK is 0800 069 8505.
Best Answer12-29-2019 19:41
12-29-2019 19:41
The charge3 is not durable at all. It's supposed to be water resistant too, haha. I had the charge2 and loved it. A bit bulky but boasts remote control for audio files. Its old now but good if you can find one.
Best Answer01-09-2020 06:43
01-09-2020 06:43
Hi, even tried the approach suggested in the best answer. However it still does not work. The screen is still black. Please help. thanks!
02-03-2020 12:11
02-03-2020 12:11
I have followed the tips I’ve found online. I have restarted multiple times each day. Later, I tap it again and it’s blank. I have made sure that the constant sync mode is off, I have turned off all notifications. There is no reason why it should be “draining” quickly, A few days ago it was working fine, as it has been since I got it. But no more. What is up? What has changed all of a sudden? (I did change 3 time zones, which I thought maybe messed with it but I’ve since restarted it, and restarted it, and restarted it. It looks like it’s working fine when it first comes on but then a bit later, black screen again!
help!
Best Answer05-01-2020 14:20
05-01-2020 14:20
My Fitbit won’t turn on at all. I’ve tried Three different chargers, and three different outlets. I know it’s completely off because the the app says can’t find Versa. Not sure what else to do.
Best Answer05-07-2020 18:02
05-07-2020 18:02
I've been having issues with my fitbit all day. It has now turned black and won't turn on or resset
Best Answer05-25-2020 06:49
05-25-2020 06:49
My Fitbit charge 3 won’t turn on and all I am getting is a blank screen. i have tried to reset but doesn’t seem to work
please can someone help
Best Answer09-03-2020 13:44
09-03-2020 13:44
I'm having the same issue. I've tried all the troubleshooting tips but it still won't turn on. Would you kindly please assist.
Thank you in advance
Best Answer09-03-2020 16:53
09-03-2020 16:53
Best Answer09-13-2020 06:52
09-13-2020 06:52
I tried holding until the smile but I am still getting a black screen. If I press the button it comes up yellow.
Best Answer11-06-2020 06:22
11-06-2020 06:22
Dear Selma: my FitBit Charge 3 is simply dead. I've had for less than 2 years. I've tried all the tips and instructions that appear on this site to no avail. Any ideas?
Thank you and kind regards,
RCDT
09:14
05:51
11-19-2020
09:14
05:51
@RCDT Welcome to the Community.
Sorry to hear that your Charge 3 isn't working as it should and thank you for troubleshooting this issue. I noticed that you already have a ticket with our Support team so keep working with them to find a solution.
Best Answer02-25-2021 03:53
02-25-2021 03:53
My charge 3 is dead
How can I revive?
Best Answer03-20-2021 05:55
03-20-2021 05:55
This did not work for me
I have a blank screen and the Charge3 won’t restart (Yes, it’s connected to the charger)
04:53
05:03
WilsonFitbit
07-01-2021
04:53
05:03
WilsonFitbit
Why do I get "access denied" when I try to see your post that *might* be able to solve my problem!?
Didn't work.
Moderator Edit: Merged posts
05:10
05:49
07-01-2021
05:10
05:49
Hello @chuck_sensei. Welcome to the community forums.
I'm sorry for any inconvenience. Here's the link for the post that contains troubleshooting steps. If you've followed those tips and the inconvenience persists, my best recommendation is that you please contact our Support Team for further assistance.
Note that you can contact them through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
