11-03-2018
15:43
15:03
11-03-2018
15:43
15:03
I am having issues with my Fitbit Charge, the screen won’t come on but there is a flashy green light and I tried to charge and the screen still won’t come on. Why is this happening? I haven’t even had this watch for a month, can you anyone assist?
07-20-2019 19:18
07-20-2019 19:18
Best Answer07-21-2019 06:04
07-21-2019 06:04
I bought charge 3 yesterday. It did sync and connect first time. It started the update process and went to install and didn’t go any further. Now it is off and I can’t get it turned back on. Trying all the steps listed nothing is working. Seeing all the problems on the forums looking at just returning this device. Have had a Charge HR for years and never once had a problem. There is no vibrate or anything when I plug it in.
Best Answer07-21-2019 06:30
07-21-2019 06:30
07-21-2019 09:26
07-21-2019 09:26
07-21-2019
10:02
10:19
07-21-2019
10:02
10:19
Hi all, thanks for your participation in the Community.
I am sorry for the delay in respond and appreciate all the efforts in trying to fix this display issue. @Jennylea6921, @AlexThom, @Lam_nguyen, @Dhill1232 and @smith1964us, appreciate the input.
@AndyFeys, @Hansen_rebekah, @MarieJ.D, @TerryMc, @Fayranshae, @Nithiya, @RDH90 and @Betyboo, if your Charge 3 won't turn on, I recommend taking a look at this post and make sure you have tried the instructions provided there.
@Hotchick_8686, @samcandles, @BritinBelgium, @Mikeha59 and @Claireb40, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else. ![]()
Best Answer07-21-2019 10:59
07-21-2019 10:59
Best Answer07-21-2019 12:00
07-21-2019 12:00
Once I connected it to the computer, everthing works fine. If I could not have solved it, I would have called customer service. Thank you for reaching out to all of us.
Best Answer07-21-2019 12:02
07-21-2019 12:02
It took about 10 minutes to update mine & it works great.
Best Answer07-21-2019 12:06
07-21-2019 12:06
Two of mine died in less than three months.
After many year I completely switched to the competition, and I'm now a happy dude who counts this thread getting longer (over 200 and counting, only here, and Fitbit admit NOTHING) :-)))
Best Answer07-21-2019 12:50
07-21-2019 12:50
07-21-2019 20:55
07-21-2019 20:55
Best Answer07-24-2019 09:45
07-24-2019 09:45
I did that to and still won't charge or come on
Best Answer07-25-2019 07:08
07-25-2019 07:08
I have had my charge 3 for a while now and have had the black screen on and off from the beginning, it used to comeback with a clock change, but now it has now happened 3 days in a row, day one clock change did not work, but I was able to perform the reset, day 2 I was unable to perform the reset with my 3rd party cable at work, but after a few tries I got it to reset at home with the original cable, now it has happened for a third day and I cannot reset.
are there any other resolutions other than the reset and clock change?
I like my fitbit when its working but this needs better resolution
Best Answer07-25-2019 09:00
07-25-2019 09:00
Tried everything . Have returned my Fitbit for replacement.
Best Answer07-25-2019 09:01
07-25-2019 09:01
@ORANGEinINDY wrote:I have had my charge 3 for a while now and have had the black screen on and off from the beginning, it used to comeback with a clock change, but now it has now happened 3 days in a row, day one clock change did not work, but I was able to perform the reset, day 2 I was unable to perform the reset with my 3rd party cable at work, but after a few tries I got it to reset at home with the original cable, now it has happened for a third day and I cannot reset.
An Update...third day, still no resolution with clock change or reset, but I found instructions for the long reset and I have display again. I needed longer than the 15 sec hold (25, 35 sec, maybe a bit more).
The fact that it is getting worse worries me. Is FitBit doing any thing to actually RESOLVE this? The term on this thread "Solved" is not true, it is a band-aid at best
Best Answer07-25-2019 09:03
07-25-2019 09:03
I have returned mine for replacement. Only had it for 2 weeks.
Best Answer07-25-2019 12:40
07-25-2019 12:40
One more update... while the screen still comes on, the bottom portion flickers, and kinda 'pixelates'
Best Answer07-25-2019 13:57
07-25-2019 13:57
I was in love with Fitbit for more than 4 years, and the charge 3 changed my mind in three months. Switch brand!
Best Answer07-25-2019 15:20
07-25-2019 15:20
Why what changed your mind so radically?
Best Answer07-25-2019 21:54
07-25-2019 21:54
