11-03-2018
15:43
15:03
11-03-2018
15:43
15:03
I am having issues with my Fitbit Charge, the screen won’t come on but there is a flashy green light and I tried to charge and the screen still won’t come on. Why is this happening? I haven’t even had this watch for a month, can you anyone assist?
08-08-2019 14:37
08-08-2019 14:37
Hi everyone. Thanks for taking the time to joining this thread, and I'm sorry for the delay in my response. I'll continue helping you with your Charge 3.
@samcandles, @CapeCodLady, @Mikeha59, @Jennylea6921, @Wandaasbury, @ORANGEinINDY, @samcandles, @JosephineR and @luciesuarez, thanks for troubleshooting your devices, as well for contacting our Support Team. I'm glad that your replacement devices are working fine, and I'm sure you'll crush your goals with those ones.
@taituara @Mikeha59 and @SYMON, I appreciate you for taking the time to share your feedback. I see where are you coming from, and I'm sorry that you've had this experience. Our team often reviews the Community to work on our devices based on your comments, and be sure that this'll not go unnoticed.
@Dtorres1085, thanks for sharing detailed information about your Charge 3's behavior. I understand how you're feeling about this situation, and I've requested a case on your behalf so our team can give you a hand. They'll contact you back via email, keep an eye on your inbox.
@Anabanna, @Jlgardner, @Hoboken, @SunsetRunner, @2mimi and @SunsetRunner, thanks for letting me know about your Charge 3, as well for the steps that you tried prior posting. Good job! I've contacted our team and apparently a case was already opened for you helped you with this situation via email hecked with our Support Team and apparently you already have a case created with them. They'll continue working with you via email.
@ZinheadJulie, I'm glad that the suggestions posted in this thread worked for you, and thanks for your efforts!
For anyone else that is experiencing this behavior on the Charge 3, I'd recommend to check the steps posted by @AlejandraFitbit, as they've worked for others.
See you around.
08-08-2019 19:57
08-08-2019 19:57
This happened to my fitbit between getting to work and lunchtime today ... I have tried everything, including changing the clock face ... Nothing happens ... No smiley face ... Just a black screen ... I am so disappointed ... As well as angry ... I don't have money to throw away like this ... 😡
08-09-2019 01:16
08-09-2019 01:16
08-09-2019 01:20
08-09-2019 01:20
08-09-2019 03:10
08-09-2019 03:10
08-09-2019 04:47
08-09-2019 04:47
08-09-2019 06:30
08-09-2019 06:30
08-09-2019 07:24
08-09-2019 07:24
08-11-2019 08:20
08-11-2019 08:20
Thanks a million for your help and support in this thread @SunsetRunner @Mikeha59. Your comments are greatly appreciated.
@SunDiva Sorry about what happened to your Fitbit. I've check with our support team and I was informed that you already have a case open for this issue. I'm sure they will be glad to give you a hand with this. Thanks for the steps that you've tried until now and reaching out our support team.
@JosephineR Thanks for reaching out again. In your case, I've request a ticket on your behalf and our team will be getting back to you via email to help you out with any inquiry you might have about your Fitbit.
I'll be around in case that you need anything else.
08-12-2019 07:23
08-12-2019 07:23
I followed all of the steps you recommended. The Fitbit vibrates when I change the clock setting but it is still black. This is the second Fitbit charge 3 that has done this. Before it did this, when I would get my Fitbit report for the week, it only recorded half of my week. I’m so frustrated with the Fitbit each and I’m thinking of other options for an exercise tracker other than a Fitbit. I’m just frustrated at this moment. I’m a runner and this watch is not serving the purpose I need it to.
Best Answer08-12-2019 18:41
08-12-2019 18:41
Best Answer08-14-2019 03:00
08-14-2019 03:00
My charge 3 replacement arrived safely today , only took a day to arrive. Thank you. My question is can I have both my charger 2 and charge3 on my iPhone simultaneously?
Best Answer08-15-2019 07:49
08-15-2019 07:49
I have tried all suggestions from community and still can't get it to work, My charge 3 is vibrating but not switching on
Best Answer08-15-2019 11:46
08-15-2019 11:46
Just minutes ago, landed in the same boat as all of the above. Went through all of the reset options, uploaded new firmware, changed faces, etc. Fitbit is still blank. Just before it went out, the display sort of freaked out and turned into a series of lines across the top of the screen - maybe a hardware failure?
How do I get in touch with customer support?
Best Answer08-15-2019 15:25
08-15-2019 15:25
I've tried all that. The Charge 3 is working, it buzzes and vibrates. I changed the clock face, did numerous short and long reboots to no avail, the screen is still blank.
Next idea??
Best Answer08-15-2019 15:32
08-15-2019 15:32
Best Answer08-15-2019 16:30
08-15-2019 16:30
Best Answer08-15-2019 16:32
08-15-2019 16:32
Best Answer08-16-2019 01:04
08-16-2019 01:04
Best Answer08-16-2019 02:12
08-16-2019 02:12
