11-26-2018
22:15
14:34
11-26-2018
22:15
14:34
hi, i just bought charge 3, and it can't be turn on. when i plug to the charger, it's only vibrate, i try to restart it, i pressed for 8 seconds then the smiling face comes up but then it shut down again.
09-21-2022 03:58
09-21-2022 03:58
I have tried all options and it still won’t turn on. When I try holding the button down, it vibrates when I push it but then vibrates again 2 seconds later even though I’m still holding the button. No matter how long I try holding the button nothing appears on the screen.
07:19
09:06
09-23-2022
07:19
09:06
Welcome to the Fitbit Community, @JessCad. Thank you for letting us know that you try restarting your Charge 3 in order to turn it on.
Could you please confirm that you have changed a clock face: How do I change the clock face on my Fitbit device?
Best Answer09-25-2022 00:09
09-25-2022 00:09
07:33
09:06
09-27-2022
07:33
09:06
Thanks for getting back to us and for sharing your experience @MCcormackn.
I´m glad to hear that you have had no difficulties with the new Charge 4.
Best Answer11-28-2022 01:11
11-28-2022 01:11
I recommend restarting the trackers. If the restart process doesn't work, perform a long restart: Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds.
Regards,
Will
