Charge 3 won't turn on
Hi there,
I didn’t wear my Fitbit for a week & the battery was dead. I put it into charge & when it came on the time was wrong. I pressed the reboot button and it turned off, but would not turn back on. I put it in the USB cable connected to power & the smiley face appears but then turns off again.
I have tried to get the smiley face & disconnect it & then reconnect it again but then it still doesn’t come on. Any advise would be appreciated!
Thanks in anticipation
4 REPLIES 4
Welcome to the Community, @Monzizim62.
Thanks for troubleshooting this turning on issue. If your tracker isn't responding, I recommend taking a look at this post and follow the instructions provided there.
Let me know the outcome. 🙂
Hi, thanks for the reply. I tried the 15 second & the Fitbit vibrates and a smiley face appears but then goes blank again. I can’t connect it to Bluetooth at all to change clock face.
Moderator edit: format
Thanks for the update, @Monzizim62.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 🙂
I have done everything that you have suggested:
I have cleaned with rubbing alcohol
i have used a different USB plug in
I have followed all the prompts
it still only vibrates very little & smiley face comes on for a few seconds & then off again.
