Charge 3 won't turn on
When connected to charger it does nothing, when side button pressed it gives on long vibrate/buzz, then nothing. Green light on inside permanently on, left hand connector looks marked/pushed in. Cleaned with dry toothbrush/cloth, no change.
1 REPLY 1
Welcome to the Community, @nickknowles.
Thanks for troubleshooting this turning on issue. If your tracker isn't turning on, I recommend taking a look at this post and make sure you followed the instructions provided there.
Let me know the outcome.
