Charge 3 won't turn on
Yesterday my fit bit was continously vibrating flashing between screens, now today won't turn on
3 REPLIES 3
@Rtravers Welcome to the Fitbit Community!
Let me help you with your Charge 3 not turning on. Not sure if this may be a battery issue or a display one so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
Alvaro | Community Moderator
Thanks for your assistance, I've tried what you suggested, still having no luck, it's a disaster, 4th day now, once I put in on charge, a smiley face comes up and continues to annoyingly vibrate.
Sent from Yahoo Mail on Android
@Rtravers thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
