Charge 3 won't turn on
My fitbit charge 3 is not turning on. I try to reset and it continues black. Its on the charger and i can hear it vibrate
2 REPLIES 2
Welcome to the Community, @Looney20.
I appreciate all the efforts in trying to fix this display issue. If your tracker isn't turning on, I recommend taking a look at this post and make sure you have followed all the instructions there.
Let me know the outcome.
Hi @Looney20 you might have a "blank screen"... maybe try contacting a moderator to see if they can help you
Akasdeep
