06-14-2021
05:54
06:02
WilsonFitbit
06-14-2021
05:54
06:02
WilsonFitbit
Yesterday my charge 3 started blinking and vibrating to change the do not disturb, screen wake option. It would sync to my phone to change the clock face to see if that would fix it, but it did not fix the issue . I put it on the charger to see if that would reset everything and now today it won't sync nor turn on.
06-14-2021 06:09
06-14-2021 06:09
Hello @Lillou75. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting. If you haven't done so, I'd recommend performing a restart to your Charge 3 and you can complete this, by following the instructions here: How do I restart my Fitbit device?
If that doesn't work, please perform a long restart. A long restart is different than the basic one and you can complete it by following the steps below:
After this, please test your Charge 3 and if it turns on but it still refuses to sync, please check: Why won't my Fitbit device sync?
Hope this helps.
