06-04-2022
09:48
14:20
06-04-2022
09:48
14:20
Ever since the latest update to 3.60 about a week ago, my Charge 4 no longer provides “reminders to move” on the hour (if I haven’t gotten in at least 250 steps). All other vibration alerts work (alarms, timers, interval workouts, etc). The “reminder to move” button is on. I have contacted customer support twice on this and neither time has the problem been fixed. I am beginning to wonder if the new 3.60 update is the problem and, if so, thought to ask this forum to see if others have experienced the same malfunction.
06-04-2022 15:32
06-04-2022 15:32
Same for me. Drives me nuts missing my steps because I'm busy and forget.
Best Answer06-04-2022 16:02
06-04-2022 16:02
Drives me nuts, too! I have just been on the live chat for longer than I care to admit, but the customer service person I worked with seemed knowledgeable. We went through all the recommended steps. Nothing worked. Now the issue is going to another team to see if there is a resolution. BTW, does your Fitbit also show the “lost Bluetooth pairing” error notice a lot? Mine does and I mentioned it to customer service to see if there is a connection (pardon the pun!). We’ll see.
Best Answer06-04-2022 19:00
06-04-2022 19:00
Best Answer06-05-2022 04:15
06-05-2022 04:15
Thanks. That’s helpful to know.
Best Answer06-07-2022 10:02 - edited 06-07-2022 10:40
Since a few months, my Charge4 is not buzzing (vibrating) anymore when I hit 10000 steps.
It also does not buzz 10 minutes before the hour to remind me that I should do at least 250 steps per hour.
The settings in my app are correct (10000 steps- reminders between 9:00 and 19:00). I did work properly some time ago.
The Charge4 is still vibrating with the alarm. So it is not broken 😉
Is there maybe a setting that I accidentally changed?
I already did a soft reset.
Firmware version= 48.20001.100.43
My Fitbit-app is running on a Samsung S7
Best Answer06-07-2022 21:43
06-07-2022 21:43
I am having the same issue and it's driving me crazy!
06-07-2022 21:46
06-07-2022 21:46
Mine is doing the same thing. There is another post on here about the same thing as well and it looks like it may have something to do with an update that was done.
Best Answer06-08-2022 03:54
06-08-2022 03:54
My “reminders to move” problem has been fixed! The reminders rearmed functioning with 24 hours of the matter being referred to another team. (See my second post above - the matter was referred after all the recommended actions were attempted but unsuccessful. So I recommend you contact Fitbit to see if you can get them to fix it remotely. Good luck.
Best Answer06-08-2022 03:55
06-08-2022 03:55
Rearmed = resumed
Best Answer06-08-2022 12:10
06-08-2022 12:10
Resetting my fitbit corrected my issues! I contacted Fitbit and they walked me through resetting it and turning my reminders off and then back on again and it fixed it!
06-08-2022 12:12
06-08-2022 12:12
I contacted Fitbit support through the chat feature this morning and they walked me through resetting my Fitbit. After I reset it they had me turn my reminders off and then back on again and it fixed my issues! I would suggest contacting them and having them help you. They were very helpful.
06-08-2022 18:53
06-08-2022 18:53
Hi everybody! Thank you for your messages.
@teamroper1997 , Thank you for taking the time to contact Support and sharing that the restart helped you.
To everyone else, here you'll find the info on how to restart the Charge 4How do I restart my Fitbit device?
Hope it helps you too.
