Charge 4 - Can’t finish activity
My Fitbit seems to have got stuck. I started an activity and can’t seem to get back to the finish screen
Moderator edit:  updated subject for clarity
1 REPLY 1
@Heloli64 , A warm welcome to the Community ! Thank you for  your message.
Have you tried restarting the Charge 4?
  • Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  • Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
  • Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display.
  • Press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
