05-20-2020
05:03
16:20
05-20-2020
05:03
16:20
At night I try to turn on DND (sleep mode hasn't pushed through yet), but it won't set. I go to setting on my Fitbit and select DND and On. However when I use the side buttons to go back to my clock face it just goes back to DND being off. Am I doing something wrong?
05-21-2020 05:11
05-21-2020 05:11
Welcome to the Community, @ccraville.
Thanks for this information, if you want to turn on this feature, make sure to do the following:
You can also try to restart your device by following the steps in the article: How do I restart my Fitbit device?.
Let me know the outcome. 🙂
Best Answer05-21-2020 06:26
05-21-2020 06:26
I've done all that repeatedly. The minute I leave the DND screen it resets itself to off.
05-21-2020
17:45
06:07
AlejandraFitbit
05-21-2020
17:45
06:07
AlejandraFitbit
Why if I turn off heart rate zone notifications does the Charge 4 still give a vibrate notification when in the golf mode? Why if I turn on do not disturb does the Charge 4 still give notifications about zone minutes?
Does do not disturb really not mean do not disturb? How can I be in golf exercise mode and turn off all notifications so I don't get annoying vibrations during my back swing?
The Charge 4 is becoming a big disappoint!
05-22-2020 11:44
05-22-2020 11:44
Thanks for getting back, @ccraville and @ScubaRW50, it's great to see you here.
I understand how are you feeling and appreciate the information provided. The DND icon dims to indicate that all notifications, including goal celebrations and reminders to move, are turned off. Can you please confirm this?.
You can also check the article: How do I navigate my Fitbit device's screen?.
Keep me posted.
Best Answer05-22-2020 19:25
05-22-2020 19:25
Best Answer10-14-2020 00:22
10-14-2020 00:22
Hi did you ever sort this problem out because mine is doing the same its so bloody annoying
12-24-2020 09:30 - edited 12-24-2020 09:30
same, so annoying. i’m trying to keep DND off so my fitbit will vibrate when i get a phone a call —- it CONSTANTLY goes on and i miss calls,, drives me nuts. the software / app sucks — should have kept my old device
03-15-2021 04:33
03-15-2021 04:33
Did you ever get this resolved? I'm having the same problem
Thank you
Best Answer03-15-2021 05:22
03-15-2021 05:22
Yes — seems to be working now .. just hit side bar twice and made sure icon didn’t have white dot lit up. horrible design, i never use timer / alarm any more bc doesn’t let u set up on app like before and now my steps not recognized on my fitness pal — prob going to buy apple watch after using fitbit since 2015...
Best Answer05-11-2021 11:38
05-11-2021 11:38
This is the same for me. Any updates?
03-28-2022 15:59 - edited 03-28-2022 16:00
There are two ways on the Fitbit to access DND. You can hold the button or swipe left to get to Settings.DND icon will be dark for off. Then make sure it is sinking.
I got mine to work by force stopping the app, clearing cache and restarting the watch. Fitbit Charge 4/Settings/About/reboot.
Hope this works for you.
Best Answer06-14-2023 09:41
06-14-2023 09:41
Mine does the same. Very annoying
