01-08-2022
07:58
16:01
01-08-2022
07:58
16:01
I received a Charge 4 at Christmas and have been wearing it since then. I started tracking my fluid intake at that time. I always enter the amount consumed using the app on my iPad (actually didn’t realise I could enter the amount directly on the watch). Oddly, one amount entered every day (usually the first) is left out of the daily total - if I have 3 drinks of 300, 250 and 300ml the daily totals will show as 550ml even though all three drinks appear on the list. Since most drinks are in the 250-300ml range it is a pain to have to go through the list deleting and then re-entering amounts until the correct total shows. Is there a “fix” for this?
01-19-2022 17:41
01-19-2022 17:41
Thank you for visiting the Fitbit Community, @LhgVerkade.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 4. Thank you for the information provided.
In this case, I would recommend restarting your Tracker by following these instructions.
In addition, you can set up your Charge 4 as a replacement device:
Hope this helps.
09:18
13:36
EdsonFitbit
01-21-2022
09:18
13:36
EdsonFitbit
I have tried the suggested fixes but unfortunately the problem is still occurring. Here is a typical screen shot after inputting 300 and then 275ml. To fix the total I will have to delete all entries and then re-enter them one by one.
Thanks,
[X]
Sent from my iPad
Best Answer01-23-2022 13:36
01-23-2022 13:36
Thanks for your response, @LhgVerkade.
The best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
