05-03-2020
03:03
16:17
05-03-2020
03:03
16:17
HI, I just purchased a Fitbit Charge 4, when i click on the agenda app the following message comes up: 'Sync calendars to your tracker in the Fitbit mobile app'.
Fitbit app has permission to use the calendar (google calendar), notifications are turned on for the google calendar within the Fitbit app, I have tried to restart both devices I have also tried clearing cache and force stopping.
Can anyone offer some guidance on this matter?
05-04-2020 06:36
05-04-2020 06:36
Welcome to the Community, @reason17.
I appreciate all the efforts in trying to fix this agenda issue. Please take a look at the help article: How do I set up and troubleshoot apps on my Fitbit device? and follow the instructions provided there.
Let me know the outcome. 🙂
06-21-2020 10:11
06-21-2020 10:11
Completely, and knowingly, worthless advice. After giving permissions, clicking on the gear to choose which calendars to link, the only option down is whether or not to show 15 minute blocks of free time. No calendars to link to are shown.
07-10-2020 12:09
07-10-2020 12:09
I might have found the answer. At least, this worked for me. I have an Android (Samsung) phone with a Charge 4.
In the app on my phone I did the following:
I hope this works for you as well. 🙂
07-10-2020 20:48 - edited 07-10-2020 20:52
Thank you, Intrepidshe, everything you say makes sense, and follows the
instructions in the manual. And I did it some time ago, but always when I
opened agenda there was nothing there but instructions to turn the
permissions on, which were already on.
But after reading your post, I went back and turned each of the permissions
off, and then back on.
And again, nothing on the agenda screen but instructions to make sure the
permissions were on - for just a second! Then the screen changed, and the
agenda app was working!, telling me correctly I had nothing on my agenda
for the remainder of the day, offering to check tomorrow, & voila, 3 items.
So thank you. Not sure if turning permissions off and then on (they had
been on for a couple of weeks) did the magic, but something worked!
Maybe the key was clicking on the agenda icon, not the gear. Tho when I did that, all three permissions were on.
BTW, I have a first gen Pixel XL.
Best, Jim
07-11-2020 09:06
07-11-2020 09:06
I'm glad to hear it finally worked. What a difficult experience. Good for you for having such persistence! 🙂
Best Answer07-12-2020 10:07
07-12-2020 10:07
Following your steps, my permissions were already set, but turning them off and on made the Charge 4 recognize it. Thanks!
07-12-2020 12:37
07-12-2020 12:37
Best Answer07-12-2020 12:40
07-12-2020 12:40
Yes, that's great news! Seems like we've stumbled on a bug they need to fix.
It's great to know we've discovered the workaround. 🙂
Best Answer08-01-2020 03:00
08-01-2020 03:00
Thanks 😊 this worked!
Best Answer09-13-2020 12:56
09-13-2020 12:56
Worked for me too!!! 😁
10-01-2020 14:41
10-01-2020 14:41
Worked for me too. Thank you!
10-02-2020
08:49
07:56
10-02-2020
08:49
07:56
Hey @GlenSiegel and @Kc987, thanks for your participation in the Forums.
I am glad to see here that the tips provided worked and that your trackers are now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
Best Answer11-11-2020 16:34
11-11-2020 16:34
Using iPhone 6 w/ the charge 4, my 1st wearable anything. I was having the same problem as OP, agenda app not working, and clicking the app(not the gear) was the ticket to fixing it. Thanks buddy.
Best Answer11-13-2020 21:52 - edited 11-15-2020 17:56
There doesn't appear to be any gear icon in the app. All instructions that mention using the gear icon to either sign in or whatever depending on the app - on my phone, a Pixel 5, no gear icon exists.
Turning permissions off and on don't work for me.
UPDATE: after spending about an hour looking all of this up it appears that I don't have the latest firmware update. From what I'm finding in other posts you just have to wait until the firmware is available.
Once I get the firmware and update it I will post back with my results. I'm assuming this will resolve all of the issues.
UPDATE 2: I finally received the firmware update and as soon as that was installed, those gear icons did show up! So if anybody else is coming to this thread and has recently purchased a Charge 4, check the firmware version because that's probably the issue.
Best Answer11-13-2020 23:40 - edited 11-13-2020 23:40
find all the help instructions very fustrating, thank goodness for this forum, turning the permissions off and on has worked!
thank you !!!!!
11-14-2020 13:10 - edited 11-14-2020 13:11
In the Fitbit app,
.Try clicking your picture (top left)
.Scroll down to help and support
.click check for charge 4 update
hope this helps.
Best Answer11-14-2020 14:20
11-14-2020 14:20
Thanks - I tried that and it says it's up to date however I still have the older firmware version.
My husband and I got these at the same time yesterday and he received his update this morning but I have not yet.
Best Answer12-27-2020 12:06
12-27-2020 12:06
thank you Swimjay and intrepidshe! I was going bonkers with the instructions and Google search. Never saw a gearbox, and most of the instructions were an exercise in futilty😒. The reset of the permissions from on to off, then back on was the final trick that worked for me.
thanks again!
12-31-2020 13:00
12-31-2020 13:00
Thank you, this worked for me!
