10-20-2023
15:22
09:11
ManuFitbit
10-20-2023
15:22
09:11
ManuFitbit
I have uninstalled, installed, rebooted phone, reset charge 4 to factory, rebooted charge 4 manu many time.
Just not able to get fitbit app to recognise the charge 4. Somehow app triggers the pin number which charge 4 shows. Once you enter this on the app, says connecting, buy nothing.
Cleared cache. Cleared data.
Help. Losing faith in fitbit
Moderator edit: clarified subject.
10-21-2023 09:10
10-21-2023 09:10
A warm welcome to the forums @Pateldin.
Thank you for sharing the details regarding your Charge 4, and the attempts to set it up.
While reading your post, I'm wondering if by any case before you had this tracker set up with an other phone. If that is correct would explain the connectivity issues you're running into. With that said, try the steps below:
