12-04-2021
06:40
16:06
12-04-2021
06:40
16:06
Tracked run on Fitbit app. Sync seemed to work. I had run 4.9 miles. It is now showing 0.72 miles. Why?
12-06-2021 16:50
12-06-2021 16:50
@Nelliep1401 A warm welcome to the Community! Thank you for your message.
Just to avoid confusions and to have a closer look at your situation, could you please clarify if the run you recorded, was done with the Fitbit app (on your phone ) or the activity app on the tracker?
Where you using GPS?
If so where you using the one on the Charge 4 or Connected GPS?
If you recorded a map, do you see the whole track on the map?
See you around.
Best Answer12-06-2021 22:41
12-06-2021 22:41
Best Answer12-07-2021 16:12
12-07-2021 16:12
@Nelliep1401 Thank you for your explanation and efforts.
Actually the steps you already did (Have tried reinstalling app, removing all data and re-setting the watch.) are the recommended steps.
Let's see if those have improved the situation.
I'll be awaiting an update to see how it went.
See you around.
Best Answer03-14-2022 23:21
03-14-2022 23:21
I managed to get a better result tracking directly on the mobile app but since upgrading it wouldn’t synch my heart rate into the exercise. I did receive a replacement Charge 4 tracker for this problem but still not resolved. This means I have to do without heart rate data in exercise or inaccurate distance.
I took part in a timed half marathon which was formally measured. Please let me know if there is anything I can do to get this more accurate. See below.
https://share.icloud.com/photos/027bbqa5HwdsF4RtuLubVA67A
Hope link works ok. Look forward to hearing from you
