05-31-2023
07:25
09:25
ManuFitbit
05-31-2023
07:25
09:25
ManuFitbit
The two pins that secures the band release mechanism to the body of the unit sheared off, the wristband will no longer remain attached to the device. Will have to try and super glue the mechanism to the body.
The band is also torn, will have to order a replacement wristband.
Moderator edit: clarified subject.
05-31-2023 11:13
05-31-2023 11:13
Hi @JLL5 go to Amazon and buy a protective cover band for the Charge 4. It actually takes the pebble piece and encompasses it, so you don't need the broken bit that the band would usually clip into. You can see these on Amazon and they are under $20, depending on which band you get.
