12-05-2020
		09:05
		16:17
		12-05-2020
		09:05
		16:17
I was taking my Fitbit Charge 4 off one day and the Band Holder broke off. I don't know if it is even possible to fix. I only have two pieces and after watching YouTube my spring is gone. One of the screw holes has a screw in it. How am I to fix this. My Fitbit was purchased in April 2020 and the website says there is no warranty when I tried to file a claim. Now I am back to my Fitbit Charge 2 which seems to be build better than the 4.
Can anyone help me?
Moderator edit: format.
05-25-2022 00:15
05-25-2022 00:15
Hey there. Yeah when mine broke, I did lose part of the band. Sorry I am not aware that a fix has been found for the problem. Fitbit does know that it's a problem. Have you contacted support ? Is the charge 4 still under warranty ? If so, have you taken it back to where you bought it?
I understand your hesitancy re: another charge 4. In my case, I got a replacement and have so far not had any issues.
Good luck with getting it all sorted.
		12:33
		16:28
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		05-27-2022
		12:33
		16:28
Hi, thank you for sharing all your feedback and that you've been having the same inconvenience with your Charge 4, @Amychlash.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
Thanks again for all the information provided; our team is always working to enhance your experience and your feedback is a big part of that process.
See you around.
07-08-2022 20:56
07-08-2022 20:56
I have the same problem, but sadly my Charge 4 is no longer under warranty. I tried to glue it back together but it won't clip. I just want to know if this is even possible to fix if I take it somewhere or am I just stuck buying one of the new, ugly models?
 Best Answer07-08-2022 23:31
07-08-2022 23:31
So sorry to hear that has occurred. I've never tried re-attaching the broken bit, so can't really say if it wold work. Not sure what Fitbit can do. Have you asked them ??? Is the Charge 4 just out of warranty ? Never know if they will help but it can't hurt to ask. Good luck
 Best Answer07-16-2022 08:58
07-16-2022 08:58
No!
People deserve to know about Fitbit's poor commitment to Customer care!
Fitbit's Charge4 band holder design/manufacturing weakness/defect has effectively destroyed otherwise perfectly good devices!!
This is a commonly, recurring problem for their Customers and yet, Fitbit has failed to make ANY solution available!!
Asking Customers to buy a new device and offering a Very Inadequate discount is disgraceful and beckon Customers loyalty to yhe brand.
Such a disloyalty to their Customers should rightfully impact their profitability!
So, let's keep letting "the community" know about Fitbit's utter disregard to their Customer's harm in such matters.
07-20-2022 15:10
07-20-2022 15:10
Gosh, mine broke yesterday. Bought in Oct 2020... Looks like design flaw. I am switching away from Fitbit after poor experience with charge 3 as well
 Best Answer07-21-2022 03:19
07-21-2022 03:19
I have the same problem with my band connector broken. I also purchased in 2020, so no warranty. Looking at new tracker and feel I should steer clear of Fitbit. I can't go back to my charge 3 as it no longer works
07-21-2022 08:40
07-21-2022 08:40
Same. Band connector thingie broke yesterday. My Charge 4 was purchased June of 2021. Tried to file a broken band claim, but it said I have no band warranty ... only the band is NOT broken, just the part on the device that enables it to connect to the band. 😞
07-21-2022 09:05
07-21-2022 09:05
I have had the same thing happen to me . I took a photo with some random number next to the broken device and received a refurbed replacement. This has broken in less than a month. I have been on chat for an hour to support receiving platitudes and no answers. It is very frustrating. The charge 4 is not fit for purpose and we should be receiving refunds or the charge 4 should be replaced with an alternative model
07-21-2022 09:48
07-21-2022 09:48
UPDATE: so ... I'm one month out of warranty so no replacement or repair for me. But they did give me a discount code to buy another device which may or may not have the same design flaw. 😞
 Best Answer07-21-2022 10:45
07-21-2022 10:45
I have the same issue with my Charge 4 as everyone else, the band holder has broken off and no way to get it fixed other than to buy another Charge 4.
However, I have found that Amazon sells a complete band with case which will accommodate the broken Charge 4 (once you remove the remaining strap). look for:
It sells for $7.49 and looks great, wears comfortably, and accepts the charger your Charge 4 came with. Got min this past February and have no complaints.
07-21-2022 13:56
07-21-2022 13:56
Unfortunately the same exact thing happened to me too, It’s happened to me twice now. Both times while taking the watch off. The first time it happened, I got a replacement. Being even more careful now, I thought the band wouldn’t break off again, but apparently I was wrong. It’s really frustrating and disappointing to have to file a claim again. The first time this problem appeared I wrote it off as a fabrication malfunction. But since this has happened twice now, I can’t help but consider this product an inferior product of the Fitbit charge line.
Now I’d like to file a second claim, since both these incidents happened in the span of one year. But when I try to file this claim through the Fitbit app, it doesn’t seem to work. I suspect that happens because I’ve filed a claim before.
Are there other ways to file a claim? Or could somebody explain to me what I could be doing wrong while trying to file a claim?
thank you, Nora.
07-21-2022 13:59
07-21-2022 13:59
 Best Answer07-22-2022 08:12
07-22-2022 08:12
Mine just broke also, and this is the second time. The band they sent me just broke in the same place… the little plastic piece with the springs popped right out from the band. Has anyone checked the Charge 5 to see if they designed them better, and if so shouldn’t they be replacing the 4’s with the 5’s??? Please help I’m lost without my Fitbit
07-22-2022 09:38
07-22-2022 09:38
I have the same problem . I have my charge 4 since last christmas. It just broke. Where can I get some help?
 Best Answer07-22-2022 09:48
07-22-2022 09:48
Same here, I broke TWO, but was within the 12 month warranty.
Not well built....at all........
07-23-2022 18:29
07-23-2022 18:29
I will be happy to send my band to you.  The part of the watch body that clasps the band and holds on to it totally broke.  Useless to even get a new band, because the band is fine, it’s the integral part built into the Fitbit that is destroyed.
My wrist is small so when the band is adjusted to fit my wrist, it must put too much pressure on the plastic part of the watch. It just slipped off my wrist the other day while I was shopping. Fortunately I felt it slip and caught it.
So now I have a Fitbit that can’t be worn because the “guts” are gone and the band can’t be attached to the watch.
Hello, Apple Watch!  Should have done that before buying my first one; this is my second.
No mas!!!!!!
07-23-2022 20:18
07-23-2022 20:18
07-24-2022 02:04
07-24-2022 02:04
 Best Answer07-25-2022 10:28
07-25-2022 10:28
My Charge 4 looks exactly like yours. Thank you for identifying the problem. I will contact customer support.
